Gear stick detached
Granthar
Switzerland
#1 Gear stick detached
Post by Granthar » Sat Mar 28, 2020 8:40 am
Hi guys
As I went into reverse my gear stick (shifter) came out- literally! Managed to get it back in. I assume the retention bolt/ nut is somehow missing? Took a look underneath but no access. Would likely need to remove gearbox? A big job. Can anyone share experience or point towards a similar thread. Many thanks. Car goes great and I am enjoying driving it at the moment, being careful not to pull on the lever
1965 S1 4.2 OTS. Opalescent silver blue. 1E 10786
#2 Re: Gear stick detached
Post by abowie » Sat Mar 28, 2020 9:06 am
Easy fix. Take the centre console out then remove the metal cover for the tunnel.
The gear stick is held in at the bottom with a nyloc nut.
Replace and enjoy!
Granthar
Switzerland
#3 Re: Gear stick detached
Post by Granthar » Sat Mar 28, 2020 5:51 pm
My thanks, a garage said it would be several hours going from bottom.
Granthar
Switzerland
#4 Re: Gear stick detached
Post by Granthar » Sat Mar 28, 2020 5:55 pm
I assume is part 60 “self locking nut” thanks for your help.
#5 Re: Gear stick detached
Post by mgcjag » Sat Mar 28, 2020 6:23 pm
Yes...60.....Steve
#6 Re: Gear stick detached
Post by 1954Etype » Sat Mar 28, 2020 6:54 pm
It won’t just be the nut you'll need. You will need to replace the bushing inside the gearstick as well.
Granthar
Switzerland
#7 Re: Gear stick detached
Post by Granthar » Sun Mar 29, 2020 12:58 pm
I figured that, parts 57-60 I would guess. Am I likely to be missing the parts labeled 49-53? Probably cheap to order them and see
Baldi70ETOTS
#8 Re: Gear stick detached
Post by Baldi70ETOTS » Thu Jul 02, 2020 11:50 am
Brilliant just what I needed...................... U guys are good !
