Coolant leak
mtnjag
#1 Coolant leak
Post by mtnjag » Sun Mar 29, 2020 6:20 pm
62 S1 3.8-Have a couple of weeping leaks at the head/block joint on the intake side. Does not appear to be the intakes to head.
Weeps enough to make it to the pan and blow around a little. Noted some slight deposits over time but since a couple of coolant changes in the last year or so for a new pump and then a radiator pull it has increased, want to stop it.
I'll try a retorque of the head first and recheck the situation once running again, doing a rear pan seal right now.
I see references here and other forums to Bars Leaks for this type of leak. They have so many products does anyone have a reference for the preferred product?
Layne
Car #876005, 62 OTS
#2 Re: Coolant leak
Post by mgcjag » Sun Mar 29, 2020 6:44 pm
Hi Layne...this is the standard old school type bars leaks iv used numerous times over the years on old classics
mtnjag
#3 Re: Coolant leak
Post by mtnjag » Sun Mar 29, 2020 7:03 pm
OK, thanks. I'll check the auto parts stores. Amazon shows it "unavailable in my area due to high demand". Hmmm. Bottle looks different that what's avail on Bars Leaks site, maybe changed to a new bottle...I'll check with them Monday. If they're open!
Layne
Car #876005, 62 OTS
#4 Re: Coolant leak
Post by chrisfell » Sun Mar 29, 2020 9:25 pm
A word of warning against barsleaks. My experience with old Brit cars is that it can’t tell the difference between a small leak and the furred up waterways in a well used radiator. It blocks them all.
I’d steer clear and deal with the leak properly, even if that means taking the head off.
mtnjag
#5 Re: Coolant leak
Post by mtnjag » Tue Mar 31, 2020 2:51 pm
Thanks. Going to borrow a pressure check tool and see just what I have going on. Try to retorque the head, and consider pulling it and using a cometic gasket which I hear good things about, I think.
Got the pan off now to fix what I hope is a rear pan seal leak and will compete that and proceed. The more I work on it the more leaks I find!
Please God, stop finding leak.
Layne
Car #876005, 62 OTS
