Series 3 power steering noise (video inside)
ljbp
Portugal
#1 Series 3 power steering noise (video inside)
Post by ljbp » Mon Apr 06, 2020 7:45 am
Hello.
I hope everyone is keeping safe.
We have a customer’s Series 3 with a noisy power steering (very noticeable between 0:11-0:14 in this video):
It’s this oil whizzing/gurgling noise when the steering is under load (even at idle speed) which I believe could be the steering rack and I thought I'd ask the forum on the chance that one of you has come across this symptom.
It’s only audible from inside the car. When outside, the engine noise drowns it, which makes it difficult to tell if it's the steering assembly or the pump.
Many thanks
alejandrovilacha
Spain
#2 Re: Series 3 power steering noise (video inside)
Post by alejandrovilacha » Fri Apr 17, 2020 4:32 pm
Hello ljbp, I have a S3 and the same sound. I think that it is completely normal.
Best Regards
Alejandro Vilachá
Colin
#3 Re: Series 3 power steering noise (video inside)
Post by Colin » Mon Apr 20, 2020 3:03 pm
Hi ljbp
To be honest I couldn't pickup the noise from the video so not sure what it is. I used to get the squealing noise from the power steering when on full lock standing still. Eventually found out it was the belt slipping. You can easily eliminate this by wetting the belt and trying it again, at least that would tell you if its a belt problem.
Good Luck
Colin
S3 V12 2+2 1973
V12 Series III 2+2 1973
ljbp
Portugal
#4 Re: Series 3 power steering noise (video inside)
Post by ljbp » Mon Apr 20, 2020 3:08 pm
Thanks Alejandro for the feedback, that's very helpful.
ljbp
Portugal
#5 Re: Series 3 power steering noise (video inside)
Post by ljbp » Mon Apr 20, 2020 3:30 pm
Thanks Colin.
If you turn the volume to max on your computer, it's becomes audible when i start turning the wheel at 0:11. It then stops at 0:15.
It's a oil flowing whizzing/wooshing noise, definitely not belt related.
Likely "you can't hear it" because it's normal as Alejandro wrote above.
