IRS shims
Joes66
#1 IRS shims
Post by Joes66 » Fri May 15, 2020 9:53 am
Hi all
Just removed my old IRS mounts from the tub on my series 2 2+2 And the front mounts apart from not having any shims in also have what seems a permanently welded on shim on the inside
Is this normal?
Will I only need to fit one shim in this case on the outside?
Many thanks for your answers
Joe
1969 series 2 2+2
Richardhealey
#2 Re: IRS shims
Post by Richardhealey » Fri May 15, 2020 10:34 pm
Hi Joe,
What you have sounds exactly what I have on my car.
Cheers,
Rich
Joes66
#3 Re: IRS shims
Post by Joes66 » Sat May 16, 2020 7:21 am
Ahh ok thx
Must have been something jaguar did to make fitting the irs more easy
I suppose I will only need one shim for the front ones then on the outside
Thx for reply
Joe
1969 series 2 2+2
