Heater return pipe support brackets location
Grant
#1 Heater return pipe support brackets location
Post by Grant » Fri May 15, 2020 2:42 pm
Hi All
Just in the midst of changing from strombergs to Su , and the question is which studs do the heater return pipe support brackets connect to exactly please .
I obviously have the triangle return spring brackets on most of them , do these heater supports share a stud with the return spring brackets ?
We have put the solid triangle bracket on the carb nearest the front of the car. Is that correct ? And does it really matter ?
Would anybody have a clear picture of under there, ?
Thank you
Grant
Series 2 OTS LHD
#2 Re: Heater return pipe support brackets location
Post by PeterCrespin » Fri May 15, 2020 9:52 pm
The small bracket used on 4.2s goes at the back to miss the starter solenoid.
Grant
#3 Re: Heater return pipe support brackets location
Post by Grant » Fri May 15, 2020 9:57 pm
Thank you Peter, that’s what I thought , seems the expert has put it on the front !
Thank you again
Grant
Series 2 OTS LHD
