Moss gearbox servicing
paydase
#1 Moss gearbox servicing
Post by paydase » Sat May 30, 2020 12:24 pm
Hi all,
I intend to service the Moss gearbox of my 3.8 FHC.
I sourced Redline MTL to do so.
I understand that draining should be done via a bottom plug and refilling via a plug on the LH side:
Before doing so, I would like to have a few confirmations and tips:
- what is the exact size of the hex plug on the side, is it metric or not? (same question for the drain plug) not to ruin the plugs if seized...
- is draining by gravity enough to empty the box from used oil?
- can the filling be done simply using a funnel and hose by gravity until oil reaches the level of the filler plug, and are new seals required for both plugs?
- and is there a possibility to later check the level with a dipstick that would be accessible from the top cover of the box? I see a dipstick mentioned on the angloparts sketch but without precise location:
I also see numerous plugs on the top cover pic but don't know what is their use:
Thx for your help
Serge
1964 (3.8) FHC
1961 OTS
lopena
#2 Re: Moss gearbox servicing
Post by lopena » Sat May 30, 2020 12:56 pm
1) definitely not metric...nothing on your Jaguar is.
2) yes, gravity draining is sufficient.
3) yes...use a funnel or a squirt-bottle to refill with Redline MTL (an excellent choice).
4) yes, you must replace the two copper crush-washers (readily available from any auto parts store).
5) I never heard of a Moss gearbox dipstick...seems like overkill for something you only need to do once a year or so.
Good luck,
Alan
N.J.
#3 Re: Moss gearbox servicing
Post by Heuer » Sat May 30, 2020 1:03 pm
Serge
The box was developed in the 1930's and uses imperial nuts, bolts and plugs.
You can drain by gravity - leave overnight
Filling is best done by using an old gear oil bottle (with the long tube) as you can squeeze the oil in. A funnel and pipe would also work
No dipstick other than your finger pushed into the level hole (Jaguar refer to it as a 'level at side of casing')
The level and drain plugs are the same - part C799 and use washer C785 (specified as fibre in the SPC)
JB Sports are the best source of parts and spares (they specialise in Morgan's): https://jb-engineering.co.uk/?page_id=77
Redline MTL is superb but for some unknown reason it improves the Moss box over time so don't be too disappointed if is not a miracle cure! Can take weeks or months but it does work.
Edit: seem to have posted this at the same time as Alan but the info is the same other than the washer material!
paydase
#4 Re: Moss gearbox servicing
Post by paydase » Sat May 30, 2020 1:12 pm
Many thaks to both of you for your quick and very useful infos and tips!
Serge
1964 (3.8) FHC
1961 OTS
lopena
#5 Re: Moss gearbox servicing
Post by lopena » Sat May 30, 2020 1:29 pm
Serge:
One last thing...since Redline MTL has a low viscosity it will exacerbate any gearbox leaks you may have. I’ve decided that the improvement in shifting performance is worth a few drops of oil on the garage floor.
Alan
N.J.
paydase
#6 Re: Moss gearbox servicing
Post by paydase » Sat May 30, 2020 3:44 pm
Thank you Alan,
I'm aware that the seals and my garage floor may disapprove but I am also willing to taste the improved smoothness brought to the Moss box :)
(although I am now used to the gymnastics of its gear changes ;))
Serge
1964 (3.8) FHC
1961 OTS
tinworm
#7 Re: Moss gearbox servicing
Post by tinworm » Sat May 30, 2020 3:55 pm
Dip stick on the previous model (XK150) as far as I know. If you look at the diagram supplied by the OP you can see the longer remote casting.
Barrie
paydase
#8 Re: Moss gearbox servicing
Post by paydase » Sat May 30, 2020 8:14 pm
Good point Barrie, that may be true.
I genuinely thought that the Moss box displayed by Angloparts was for an E-Type, as they advertise it on their website...
https://www.angloparts.com/en/catalogue ... -1961-1964
Serge
1964 (3.8) FHC
1961 OTS
paydase
#9 Re: Moss gearbox servicing
Post by paydase » Tue Jun 16, 2020 9:19 pm
A few pictures from servicing.
Very straightforward:
Serge
1964 (3.8) FHC
1961 OTS
