Gearbox tunnel - foam cover
Steve1967
#1 Gearbox tunnel - foam cover
Post by Steve1967 » Thu Jun 18, 2020 11:23 am
Hi, can anyone advise me if the 2" thick foam insert between the gearbox top and the tunnel cover is made of anything special? ie is it fire or oil resistant etc.
I have some foam I can use to do this but its from a sofa!!
Would there be a problem using this?
Many thanks
1967 E Type 4.2 series 1 OTS
1960 Austin Healey 3000 BT7
#2 Re: Gearbox tunnel - foam cover
Post by mgcjag » Thu Jun 18, 2020 11:33 am
Hi Steve....i used the blue foam from an upholster. ....its working ok....Steve
Steve1967
#3 Re: Gearbox tunnel - foam cover
Post by Steve1967 » Thu Jun 18, 2020 11:42 am
Thanks very much.
I have now found an earlier thread on this which answers all my questions.
I should have looked more thoroughly first. It appears to be OK!!
Thanks again.
tim wood
#4 Re: Gearbox tunnel - foam cover
Post by tim wood » Thu Jun 18, 2020 12:28 pm
I would have thought that fire retardant foam would be a wise choice. Modern furniture foam should be ok and the furniture marked as such.
