Steering Lock & Ignition Switch
#1 Steering Lock & Ignition Switch
Post by Bill » Thu Jul 16, 2020 1:06 pm
Ignition switch has failed. I have purchased a replacement unit from SNG Barratt (part 37103). This new unit has a number stamped on the steering lock section (WGP622) and the wires from the ignition switch terminate in a 6 pin plug.
The number stamped on the old unit is WGP621 and the wires (White, Brown, White/yellow, White/red) terminate in a 4 pin plug (which fits into a 4 pin plug in the wiring harness).
Part # 37103 is the part listed for my Series 3 Roadster in the SNG Barratt catalogue - I have emailed them for clarification and/or what changes I need to make to the unit supplied to make it fit my vehicle. I ma awaiting a response - has anyone out there experienced a similar issue?
Cheers,
OOPS - numbers stamped on the steering lock are - New unit WGB622 - Old unit WGB621
Nialls Shortbear
Virgin Islands (USA)
#2 Re: Steering Lock & Ignition Switch
Post by Nialls Shortbear » Thu Jul 16, 2020 11:39 pm
Sir,
What year is Car?
What colour wires on new switch. Are you sure white/red on old switch is not white/pink?
#3 Re: Steering Lock & Ignition Switch
Post by abowie » Fri Jul 17, 2020 3:05 am
It's likely that the original units are NLA and the switch you have been sent is the next best option. You may have to rewire the plug to suit your vehicle.
#4 Re: Steering Lock & Ignition Switch
Post by Bill » Fri Jul 17, 2020 6:33 am
G'day Nialls & Andrew,
Car is RHD Manual Roadster - left the factory August 1973. Yep, lead is White/pink (not red). Looking a the switch from the rear, the wiring is the same except for the additional 2 middle connections.
Top left contact lead to plug is White on both new and old.
Top right contact lead to plug is Brown** " " " "
Bottom left contact lead to plug is White/pink " " " "
Bottom right contact lead to plug is White/yellow " " " "
Middle left contact lead to plug is thin Brown (new unit only). This connects to the same pin as the top right/Brown lead** new switch only.
Middle right contact lead is thin Brown/red.
The two additional/middle leads run to the two additional pins on the plug - I'm thinking I ought to be able to cut the side off the plug, removing these two additional pins, allowing the plug to then fit to the 4 pin socket in the loom under the dash? Reluctant to do this just yet ($A858.00 "investment"). Thanks for your interest, would appreciate any further thoughts you might have.
Cheers,
