308601 CC2. (Might just be the casting number.)
The push rod that is fixed to the clutch pedal doesn’t seem to have anything to attach the other end to the piston. In other words the push rod can push the piston long the bore of the cylinder, but cannot pull it back. Is this correct?
I cannot bleed and get the system to work. What pushes/pulls the piston back along the cylinder? I thought it may be the actual clutch pressure plate when the pedal is released but of course you can’t get that effect until the system is full of fluid and operational.
I’ve looked in my manuals, Jaguars parts catalogue, on the web, on spare part suppliers diagrams, they all show a different master cylinder.
Anyone, know if/how the pedal rod is attached to the cylinder piston?
Here’s a photo of it. Thanks very much
