OIL TEMPERATURE GAUGE
Retroman
#1 OIL TEMPERATURE GAUGE
Post by Retroman » Sun Jul 19, 2020 2:05 pm
Updating my oil pressure gauge to a mechanical one and wondered about getting the combined oil pressure/water temp gauge as it has a more detailed reading which provides a spare space for another instrument.
Thinking of an oil temp gauge and wonder if anyone fitted an oil temp gauge to a 4.2?
If so is it a simple job or is it not worth the hassle.
Best wishes,
Nigel.
1969 E Type Series 2 2+2 Auto with Power Steering UK Registered
dal2.0litrefrogeye
#2 Re: OIL TEMPERATURE GAUGE
Post by dal2.0litrefrogeye » Sun Jul 19, 2020 7:45 pm
Hi I have an oil temp gauge , when I made my dash and loom I decided to fit a more informative oil temp guage than the gauge that tells me if my alternator is charging or not . I now have a charge light for that . I fitted the sender for the oil temp into the the oil gallery by removing one of the plugs and fitting an adaptor into the oil gallery . I also fitted an oil light sender into one of the gallery orifices too so I now have a wet oil oil pressure gauge , an oil oil temp , and an oil pressure lamp , Regards cautious Darren of Orpington .
And no it's not to much hassle to fit
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
#3 Re: OIL TEMPERATURE GAUGE
Post by mgcjag » Sun Jul 19, 2020 8:24 pm
And what temperature are you looking for as "normal".....Steve
Retroman
#4 Re: OIL TEMPERATURE GAUGE
Post by Retroman » Sun Jul 19, 2020 8:37 pm
Slap bang in the middle of the gauge :thankyouyellow:
#5 Re: OIL TEMPERATURE GAUGE
Post by mgcjag » Sun Jul 19, 2020 9:10 pm
That dosnt sound very technical.......depends what range your guage is?.....Steve
dal2.0litrefrogeye
#6 Re: OIL TEMPERATURE GAUGE
Post by dal2.0litrefrogeye » Sun Jul 19, 2020 9:40 pm
The highest I've seen the oil temp after some fast motorway use on a hot day is 80 degrees . Normal driving is 50 . I do have an oil cooler . I'm thinking about moving the temp sender to the sump plus
