Boot Pops Open
Neil Duke
#1 Boot Pops Open
Post by Neil Duke » Mon Jul 27, 2020 7:36 pm
On mt roadster,the boot pops open when I am going over a bumpy road,anybody else had this?That is serious scuttle shake.
69 S2 2+2
07 Vanquish S
07 Vantage Roadster
65 Austin Healey 3000
66 Scimitar Coupe
He who dies with the most toys wins.
#2 Re: Boot Pops Open
Post by mgcjag » Mon Jul 27, 2020 7:54 pm
See similar topic below...Steve
Tbob
#3 Re: Boot Pops Open
Post by Tbob » Tue Jul 28, 2020 1:54 am
Mine does that occasionally. It’s usually because the T handle on the opening cable wasn’t pushed fully into its socket from the last time I operated it. I’ve got in the habit of pushing the T-handle Firmly back in after I’ve opened the boot.
Bob t
LHD '69 OTS. (Former) basket case
Neil Duke
#4 Re: Boot Pops Open
Post by Neil Duke » Tue Jul 28, 2020 11:34 am
I will try pushing the handle firmly shut.I saw another thread about climbing in the boot :wow:
69 S2 2+2
07 Vanquish S
07 Vantage Roadster
66 Scimitar Coupe
42south
New Zealand
#5 Re: Boot Pops Open
Post by 42south » Fri Jul 31, 2020 2:31 am
hi
yes mine used to do this regularly. I found two issues, firstly as mentioned make sure you push the release handle back in after opening the boot. This resets the locking mechanism.
The second issue I found was that the locking bar mounted on the Boot lid was not engaging properly with the lock mechanism in the car, I used my iphone taking delayed photos in the boot after I closed the lid to confirm this. The solution was to put washers under the locking bar plate on the boot lid to lower it. You could also just make a spacer plate to achieve the same result.
Mark Brown
Neil Duke
#6 Re: Boot Pops Open
Post by Neil Duke » Fri Jul 31, 2020 10:22 am
Thanks Mark,I will look into that.
69 S2 2+2
07 Vanquish S
07 Vantage Roadster
66 Scimitar Coupe
ianfey
#7 Re: Boot Pops Open
Post by ianfey » Fri Aug 14, 2020 9:36 am
Mine used to pop at every bump. Looking at it found that T shaped cut out in housing preventing full movement of latch so boot only holding on a sliver. Widened slot and no further problems. As insurance Wilko sell a keyring chain for about 2 pounds shorten this and with a couple of split rings you can clip body to boot lid with boot slightly open so even if boot does pop it can't open more than a few centimetres
