Spark Plugs
#1 Spark Plugs
I've just bought some Champion N9YC plugs to replace existing plugs. Have always used Champion, but the new ones look cheap, nasty and almost fake.
Anyone got any preferences? I've got an MSD Ignition system and thinking of using NGK BP5ES plugs and leaving gap factory set at 35 thou.
Thoughts appreciated
#2 Re: Spark Plugs
If you have any electronics in the car (ignition, satnav, phone etc) you should fit Resistor plugs to avoid interference. The NGK BPR5ES plugs (note the 'R' in the part number) are what I use and they are excellent.
#3 Re: Spark Plugs
#4 Re: Spark Plugs
Thanks for the advice.
The car has had Champion N9YC in it since I got it. I've been using a plug in SAT Nav without problems, and never heard interference on my phone (which of course I don't use while driving - couldn't hear it anyway) No radio in car. So....is a resistive plug really necessary? I have the basic BP5ES ready to go
#5 Re: Spark Plugs
For the cost I would certainly recommend the resistor plugs especially as you have a MSD ignition system. Bear in mind it can affect other road users even if you don't see a problem. You may get away with it but if you start noticing misfires then the non resistor could be the cause. This explains things:
"At the moment the spark jumps the gap it causes a high frequency burst of energy, this is known as RFI (radio frequency interference). This is why resistor spark plugs were introduced in the mid 1960's. Placing a resistor within the spark plug suppresses the RFI. Without resistor plugs in your car you can experience static on your radio as well as interference with other sensitive electronic equipment. Some later model vehicles as well as newer Powersport engines must use resistor plugs for a proper "talkback" to the electronic ignition. As a rule, performance is in no way impaired by resistor spark plugs."
#6 Re: Spark Plugs
You're right - since there are only pennies difference in price, I wonder why all plugs aren't made with resistors. Come to think of it, just why are there so many types??
#7 Re: Spark Plugs
Simon, if you have any doubt and think they are fake - then you could be correct.
I bought some NGK plugs for my other car (aston martin V8) from Ebay.
I ran the car last June after fitting them on a very long European road tour. Firstly we thought it was the E5 / E10 fuel abroad for the coughing and spluttering. No. On return to the UK I bought a new set from a reputable dealer being Opie oils and I compared them firstly side by side with new and old.
It was alarming and very apparent the difference in the manufacturing marks, identification marks and alarmingly how smoother the engine instantly ran after the replacements were fitted.
Smoother idle and more mpg.
All I can say is caveat emptor and buy your plugs from a reputable source as the market is flooded with fake plugs.
Clive
August 1961 Flat floor ots
#8 Re: Spark Plugs
Quite right, although unfortunately, reputable sources can also unwittingly buy fakes. The same thing happens with pharmaceuticals. So the reputation of the supplier doesn't ensure the authenticity, but does of course make it more likely you're getting the real McCoy
#9 Re: Spark Plugs
Its well known that there are fake spark plugs on e bay
Joe
Joe
1969 series 2 2+2
#10 Re: Spark Plugs
Strangely I’ve never heard of that, though I don’t buy spark plugs from fleabay I’d say that is a bit of a generalisation to imply we should all know that
#11 Re: Spark Plugs
This photo is of fake ones currently for sale on Ebay.
In this case the Fake ones have blue logo, and genuine ones have black logo and black insulator bands.
Clive
#12 Re: Spark Plugs
and how they are assembled in China ??!!
Clive
#13 Re: Spark Plugs
So we all have those photos of the assembly line?
#14 Re: Spark Plugs
A little late on this, and without questioning which is fake or not, i believe the Blue NGKs “R” are the color of their resistor plugs and black is non resistor.
I don’t note the black bands on the non resistor NGKs i have.
In many PNs they do make the same plug application with either a Resistor or Non-resistor plug, with or without the R. At least they used to. I understand from the NGK tech that they have discontinued Non-resistor plugs in other than a colder heat range for racing.
Also made with a removable threaded contact top or a fixed/permanent top for different types of spark plug loom connectors and that also has a variation in the cosmetics.
The box certainly isn’t like any NGK boxes I’ve seen but NGK does have different colored and logo’d boxes based on the type of plug.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#15 Re: Spark Plugs
Going through old NGK plugs and found some of the NGK Iridium that have the black bands. None of the the
others do. Again, the Standard Copper core NGKs- R plugs are blue logo, Non-resistor black logo with no bands.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#16 Re: Spark Plugs
#17 Re: Spark Plugs
Put in the NGK and forget it......
Champions for almost the last 20 years are made in a sweat shop in Mexico, they are junk
Ive used NGK for close to 35 years, they are the best.
gtjoey1314
gtjoey1314
