1967 E Type Question
shelby
#1 1967 E Type Question
Post by shelby » Wed Oct 14, 2020 11:23 pm
I own 1967 E Type IE15538. Based on what I have read it is close to the end of Series 1 production. It has a Series 1 hood with covered head lights. It has all the other Series 1 characteristics except one. It has the small dual fans for the radiator like the Series 1 1/2. Is it likely(possible) it came that way from the factory. I would appreciate any help. Thanks!
#2 Re: 1967 E Type Question
Post by bitsobrits » Thu Oct 15, 2020 3:14 am
Does it have the dual fans on the S1 radiator and header tank arrangement? Or the S2 type radiator with the firewall mounted header tank?
If the former, it's likely to be some sort of non factory conversion. If the latter, it may be factory, though that does seem unlikely.
Doug Buchan
#3 Re: 1967 E Type Question
Post by Doug Buchan » Thu Oct 15, 2020 10:59 am
Is the single fan mount present on your picture frame?
Doug
'67 ots
shelby
#4 Re: 1967 E Type Question
Post by shelby » Thu Oct 15, 2020 7:40 pm
Thanks for your reply. It is the S1 radiator and header tank arrangement.
#5 Re: 1967 E Type Question
Post by Heuer » Fri Oct 16, 2020 1:32 pm
Previous owner modification.
#6 Re: 1967 E Type Question
Post by mgcjag » Fri Oct 16, 2020 2:00 pm
Have you checked out xke date.....there are quite a few cars befor and after your number with open headlamps..have a look at this link http://www.xkedata.com/resources/read/?id=1h
Joes66
#7 Re: 1967 E Type Question
Post by Joes66 » Sat Oct 24, 2020 10:07 am
Sounds like it may be a series 1.5 to me
With many previous owner mods
Probably including the bonnet
Joe
1969 series 2 2+2
gtjoey
#8 Re: 1967 E Type Question
Post by gtjoey » Wed Dec 16, 2020 11:35 am
Id drive it and not worry till the battery conversion is needed when petrol is gone :)
Enjoy that ride......Im averageing 800 miles a month in my early 67 coupe....
gtjoey1314
