body plate - where do I buy it?
ggg1102
Italy
#1 body plate - where do I buy it?
Post by ggg1102 » Sun Nov 01, 2020 9:59 am
Hello everyone,
the blasting of the car damaged the body plate under the license plate on the back.
I've to change it.
Do you know where to buy it?
I haven't been able to find it yet.
Giovanni
Giovanni
S1 - 4.2 - 2+2 - march 1966
#2 Re: body plate - where do I buy it?
Post by mgcjag » Sun Nov 01, 2020 10:16 am
Robbiee
#3 Re: body plate - where do I buy it?
Post by Robbiee » Sun Nov 01, 2020 12:09 pm
The tags from Todd are great But have you considered removing your original one, cleaning it up and reriveting it on the car? I can make out your number ... so I would reuse the genuine original one!
Robbie
ggg1102
Italy
#4 Re: body plate - where do I buy it?
Post by ggg1102 » Sun Nov 01, 2020 12:26 pm
Hi Robbie. Re-use the original one was my first choice but unfortunetely it was damaged by sand used to blasting the car to remove painting.
Giovanni
Robbiee
#5 Re: body plate - where do I buy it?
Post by Robbiee » Sun Nov 01, 2020 5:24 pm
Hi Giovanni
Well, try Todd Clarke ...check the topic suggested above.
I’d still try and get the original off and work on it with wire wool and see. It’s made of aluminium and once painted it might be fine(even if not perfect). The replacements tend to be steel!
BW
Robbie
JCrosby
#6 Re: body plate - where do I buy it?
Post by JCrosby » Tue Nov 10, 2020 5:43 pm
FYI, I just obtained a replacement plate from Todd, and it is very well done. He's very pleasant to deal with, and service was extremely quick. I recommend his work.
1965 S1 4.2 OTS 1E10425
ggg1102
Italy
#7 Re: body plate - where do I buy it?
Post by ggg1102 » Sun Dec 06, 2020 9:31 am
Thanks, I'll ask to Todd Clarke.
Giovanni
Drive35
#8 Re: body plate - where do I buy it?
Post by Drive35 » Fri Dec 11, 2020 1:07 pm
I'm in contact with Todd about making a tag for my car, however we weren't aware there are 2 sizes of these tags, so he is tooling up to make the S2 & 3 ones, which are larger and bigger digit size.
Can anyone confirm that all Series 1 have tags approx 62mm (2.45") long, with holes 54mm (2.125") apart
and Series 2 & 3 are approx 70mm (2.75") long with holes 60mm (2.375") apart.
Anyone know about Series 1.5 or when they changed size?
Thanks, Geoff
1970 S2 2+2
Robbiee
#9 Re: body plate - where do I buy it?
Post by Robbiee » Fri Dec 11, 2020 6:11 pm
Follow the link earlier in the thread
I can only answer for a ‘62 S1
ggg1102
Italy
#10 Re: body plate - where do I buy it?
Post by ggg1102 » Sat Dec 12, 2020 9:13 am
Drive35 wrote: ↑
Thanks, Geoff
Hi, my old plate (serie 1, 2+2, march 1966) is about 64mm and has holes at 54mm. About other types I don't know.
Giovanni
Drive35
#11 Re: body plate - where do I buy it?
Post by Drive35 » Sat Dec 12, 2020 11:02 am
Thanks Robbie & Giovanni. Todd had already sent me a S1 tag, which was too small. Just need to find out when they changed to the larger one.
1970 S2 2+2
#12 Re: body plate - where do I buy it?
Post by Gfhug » Sat Dec 12, 2020 6:46 pm
I, too, could do with a couple of S2 body tags. If you’re successful with Todd will you let me know, please.
Then I can ask him for ones for my cars.
Cheers from another Geoff
