Which Seat Reclining Lever is it?
Pex
Sweden
#1 Which Seat Reclining Lever is it?
Post by Pex » Sat Nov 28, 2020 12:30 pm
I’m fixing my seats and need new seat reclining levers.
I have black “flat iron” ones but see that there are chromed ones, are they replaceable?
The chromed ones looks much nicer, can someone explain when they changed type.
//Peter
1969 Serie 2 OTS
#2 Re: Which Seat Reclining Lever is it?
Post by PeterCrespin » Sat Nov 28, 2020 1:42 pm
Flat iron are S1.5 then chromed S2 (with rear extensions for 2+2) and metal hinge covers, then finally similar S3 which are a bit longer and have plastic covers.
Something like that anyhow.
#3 Re: Which Seat Reclining Lever is it?
Post by mgcjag » Sat Nov 28, 2020 2:26 pm
Hi Peter...my UK 69 S2 2+2 had the black iron levers.....i fitted the chrome.....not a direct replacement and had to be fettled to fit.......dont know when the changeover was you would have to look up in the parts catalogue.....or search for photos on xkedata for when they changed.....SNGB show both types .....BD32688 for the black iron...BD35545/6 for the left and right chrome......Steve
Pex
Sweden
#4 Re: Which Seat Reclining Lever is it?
Post by Pex » Sat Nov 28, 2020 3:50 pm
Thanks, just what I thought... it is probably the original ones then.
Just ordered seat runners etc but left the levers out, I will keep them and will try to weld and grind it to fit without any play since I can always replace them later.
//Peter
1969 Serie 2 OTS
Joes66
#5 Re: Which Seat Reclining Lever is it?
Post by Joes66 » Sun Nov 29, 2020 8:03 am
Hi Peter
My series 2 2+2 has black flat iron ones as well
I think it depends on when jaguar ran out of the old ones :)
Joe
1969 series 2 2+2
#6 Re: Which Seat Reclining Lever is it?
Post by mgcjag » Sun Nov 29, 2020 9:38 am
Just looked through some photos on xke data but only for rhd S2 2+2.....early car have the black iron lever and as you get later they change to chrome....Steve
