LH bonnet diaphragm
basilruler1234
#1 LH bonnet diaphragm
Post by basilruler1234 » Tue Dec 29, 2020 12:39 pm
A bit of bonnet maintenance has led to a puzzle, the LH diaphragm in the image above has a return edge.
This tucks above the air duct as shown pointed at with the screwdriver in the image below
My question is that once the bonnet flange I'm holding up in the next image is bonded to the centre panel, I can't see how you would be able to remove the diaphragm as it will be trapped, is this the case or am I missing something? Any help as always greatly appreciated
James Guest
Series 1 4.2 '65
paulsco
#2 Re: LH bonnet diaphragm
Post by paulsco » Thu Dec 31, 2020 7:36 pm
Hi James,
Yes you are right.
It is quite difficult to remove the diaphragm once the flange is fitted, but not impossible.
It is a long time since I have done it, but you may have to loosen the duct, or possibly even the wing to wriggle it out. :sad:
