Lower wishbone, fulcrum shaft removal
Apprentice1975
#1 Lower wishbone, fulcrum shaft removal
Post by Apprentice1975 » Wed Feb 10, 2021 2:53 am
hi there e type people,
my first technical post.
A simple question I hope...
Is the lower wishbone fulcrum shaft an interference fit where it has been pressed into the wishbone when first assembled?
I've read in a previous thread that force and heat is needed to separate the shaft from the wishbone because they get seized in over time.
I'm also trying to understand how the lower wishbone reacts
with the torsional force or resistance created by the torsion bar.
Does the wishbone need to rotate freely on the fulcrum shaft?
My plan is to get the wishbones plated or powder coated after i've separated and cleaned them up..
please see a picture.
thank you
Colin
my project - XKE Series 3 2+2 manual coupe
#2 Re: Lower wishbone, fulcrum shaft removal
Post by abowie » Wed Feb 10, 2021 8:56 am
No they just rust together.
Heat and a hammer or a press will separate them, although sometimes you may damage the fulcrum shaft in doing it.
Consider the fulcrum shaft, which can be bought new, to be sacrificial if necessary, but protect the two castings as they can't.
When assembled on the car the shaft doesn't move in the castings.
Zinc plating is the way to go, unless you can get Cad plating done in Perth. We have one place in Adelaide that can do it.
Apprentice1975
#3 Re: Lower wishbone, fulcrum shaft removal
Post by Apprentice1975 » Wed Feb 10, 2021 9:08 am
thanks Andrew,
will the fulcrum shaft fit in the wishbone after it's been plated?
thanks
Colin
#4 Re: Lower wishbone, fulcrum shaft removal
Post by mgcjag » Wed Feb 10, 2021 9:17 am
Hi Colin...depends how thick the plating is....but yes they usually do.....Steve
angelw
#5 Re: Lower wishbone, fulcrum shaft removal
Post by angelw » Wed Feb 10, 2021 12:14 pm
Yes.
Apprentice1975
#6 Re: Lower wishbone, fulcrum shaft removal
Post by Apprentice1975 » Wed Feb 10, 2021 9:45 pm
thanks Bill
Colin
#7 Re: Lower wishbone, fulcrum shaft removal
Post by abowie » Thu Feb 11, 2021 2:02 am
thanks Andrew,
thanks
Yes. We always plate them on restos.
The new ones come zinc plated.
RTaillieu
#8 Re: Lower wishbone, fulcrum shaft removal
Post by RTaillieu » Thu Feb 11, 2021 3:21 am
If you buy new fulcrum shafts run a thread chaser over both ends. I bought new shafts from SNG and the nuts wouldn't screw on to the new shafts because of the plating. After using the thread chaser on them the nuts spin on nicely.
Rick
Rick
'69 E-Type 2+2
'64 Austin Healey BJ8 Ph1
#9 Re: Lower wishbone, fulcrum shaft removal
Post by Gfhug » Thu Feb 11, 2021 9:04 am
If you don't have a thread chaser a castellated nut will often do the job, run it down the threads with the castle section first.
#10 Re: Lower wishbone, fulcrum shaft removal
Post by Series1 Stu » Thu Feb 11, 2021 9:39 am
:yeahthat:
Good tip, there.
Or, you could file a groove in a sacrificial standard nut to give the same effect.
Keep reversing the nut half a turn after every full turn to break any build up of dirt and excess plating.
Apprentice1975
#11 Re: Lower wishbone, fulcrum shaft removal
Post by Apprentice1975 » Wed Feb 24, 2021 7:01 am
I finally managed to fully pull apart the first lower wishbone .
Method:
1. carefully cut through the seized bolt head that connects the 2 legs of the wishbone using an 4" angle grinder cutting disk. Pressed bolt out.
2. Tried to press out lower fulcrum shaft through both wishbone legs using my cheapo 6t press, no joy, solid....
3. Applied heat to the two legs where fulcrum shaft passes through ,, using LPG / flame flame , blow torch.
There was just enough heat to get some movement. No need for acetylene gas...
4. Pressed shaft again while hot.
A bit of messing around with my bottle jack style hydraulic press to get enough stroke for the shaft to pass.
I used welding gloves and face shield for protection.
1 down 1 to go and fingers crossed.!
thanks to all who contributed .
see some pics
Colin
