Bonnet wiring mount position on car S1 4.2
phoenix
#1 Bonnet wiring mount position on car S1 4.2
Post by phoenix » Sun Mar 07, 2021 12:20 pm
H. I need to know where to mount the (I think) socket to the front frame and I cannot seem to find any reference to its position . I also need the heater and choke controls on the dashboard . Do the LHD cars use the same parts so I can widen the search .
S1 4.2 RHD Bryan
Philk
#2 Re: Bonnet wiring mount position on car S1 4.2
Post by Philk » Sun Mar 07, 2021 1:08 pm
Re the bonnet wiring point...... The eight pin bonnet socket has a three bolt fixing plate which, in turn, is bolted to the Left Hand Headlamp Panel (this panel has an extra three fixing holes on it than the right hand panel). The connecting plug and cable is then loosely tied (normally with a flexible harness strap) towards the top of the lower nearside downleg of the bonnet support frame. Finally, there is a curved clip that is attached at the bottom of the bonnet balance link which holds the cable in place at the back of the lower bonnet valance.
1964 S1 3.8 OTS
phoenix
#3 Re: Bonnet wiring mount position on car S1 4.2
Post by phoenix » Sun Mar 07, 2021 3:26 pm
Thanks Phil :yellow: :yellow:
S1 4.2 RHD Bryan
Robsan
#4 Re: Bonnet wiring mount position on car S1 4.2
Post by Robsan » Sun Mar 07, 2021 11:33 pm
exellant description regard the bonnet wiring interface from Phil
the choke and heater control levers............. I believe they are the same whether mounted RH or LH
#5 Re: Bonnet wiring mount position on car S1 4.2
Post by Series1 Stu » Tue Mar 09, 2021 11:04 am
Both LHD & RHD cars have the choke control to the right of the centre instrument panel and the heater controls to the left of it. Therefore all parts are the same.
I think they are available from all the usual suppliers.
