Removing chromering luggage compartement opener
Desmo
#1 Removing chromering luggage compartement opener
Post by Desmo » Thu Apr 22, 2021 1:02 pm
Hello,
I would like to remove the chromering which is covering the boot lid unlock chrome lever. Have a look at the photo. How do I proceed so as not to damage anything? Thank you for your help.
Best regards
[url=https://postimg.cc/w33rHMqS]
#2 Re: Remove chromering luggage compartement opener
Post by mgcjag » Thu Apr 22, 2021 1:07 pm
Hi John.....lift the lever and you will see a tiny screw...remove it.......the outer ring is then loose.....you will have to fiddle with it with the lever raised to get it out......it only comes out one way and goes back in the same so note how it comes off....Steve
Desmo
#3 Re: Removing chromering luggage compartement opener
Post by Desmo » Fri Apr 23, 2021 3:20 pm
Hello Steve,
Thank you. Removed now without damaging anythink.
Best regards
