Brake light switch
myJagV12
Austria
#1 Brake light switch
Post by myJagV12 » Tue Jun 08, 2021 2:21 pm
Hi Jagies,
Me again :D
I can't find my brake light switch. I read that a hydraulic switch was used (maybe not in Series 3 ?) but with my later Series 3 (Feb 73) the wires (G,GP) would just reach the pedal. I can't neither locate a mounting bracket nor any signs that the pedal ever touched a switch rocker. (And I did not find the switch in any of my boxes yet.)
Anyone got a picture of how this part is supposed to look like ? Do I have to make a bracket and use a new switch ?
Please help !
Tom
E-Type Series 3 2+2, automatic, Feb 73, not back on the road yet ...
Thank you for sharing your knowledge !!!
#2 Re: Brake light switch
Post by Heuer » Tue Jun 08, 2021 2:36 pm
myJagV12
Austria
#3 Re: Brake light switch
Post by myJagV12 » Tue Jun 08, 2021 2:45 pm
So a pedal switch and I am just missing the bracket and switch ?!
Thank you very much !
I would be totally lost without your forum ! :roll:
myJagV12
Austria
#4 Re: Brake light switch
Post by myJagV12 » Tue Jun 08, 2021 3:38 pm
It is still unclear to me how the bracket shown would be mounted.
The firewall has a stiffening edge all around so the bracket would not fit if mounted to the upper of the four pedal mounting bolts and the remaining (UGLY) contact glue tells me I am maybe barking at the wrong tree.
And correct me if I'm wrong - i need an "opener" as the switch is engaged all the time unless the pedal is pressed ? So when the switch is "lying on the table" it is closed just as if the pedal was pressed and if it is engaged it opens ?
No clutch unfortunately :D
myJagV12
Austria
#5 Re: Brake light switch
Post by myJagV12 » Tue Jun 08, 2021 7:32 pm
... removed ...
I think the attached explosion drawing is misleading as it looks as if the lower bolts had to be used. Does the bracket not go the other way round ?
Still lost :scratchheadyellow:
vee12eman
Kiribati
#6 Re: Brake light switch
Post by vee12eman » Tue Jun 08, 2021 9:27 pm
Hi Tom,
Hope this will help:
Series III FHC
myJagV12
Austria
#7 Re: Brake light switch
Post by myJagV12 » Tue Jun 08, 2021 9:33 pm
Thank you Simon !!!
Yes this is it - the only way it makes sense and I already begun manufacturing (with a paper model) :D
Just the narrow holes on each side don't make sense to me and I am wondering why i can't see any marks from the formerly mounted bracket on my car.
Thank you very much - i suspect the paint-shop has dropped the missing parts.
Kind regards,
Tom
vee12eman
Kiribati
#8 Re: Brake light switch
Post by vee12eman » Tue Jun 08, 2021 11:05 pm
All good. Glad to help.
Series III FHC
myJagV12
Austria
#9 Re: Brake light switch
Post by myJagV12 » Wed Jun 09, 2021 12:57 pm
I drilled the holes a bit in the wrong position but it does the job.
I think the Hella 6DF 003 263-001 will almost look originally.
Thank you again !
