Low Oil Pressure solved
Dave Dawson
#1 Low Oil Pressure solved
Post by Dave Dawson » Mon Jun 21, 2021 1:05 pm
:oops: HI Forumites My E-type has had low oil pressure at Hot idle 10 psi since it was rebuilt by my self in 2014 . while Checking over my E-type over,[just before the 60th meet at Shelsey Walsh] i noticed an oil leak from the PRV on the oil filter head, on removing the complete head I found the gasket was fitted back to front, so oil had been leaking past the prv on the LHS, on replacing the gaskets correctly the hot idle pressure increased to 25 PSI [Smiths electrical gauge] .
:oops:
David Dawson E-type 68 S2 2+2 o/d E-Type 68 S2 OTS Frogeyed Sprite
Triumph Tr5 pi Tr3a
tinworm
#2 Re: Low Oil Pressure solved
Post by tinworm » Mon Jun 21, 2021 4:45 pm
Are you owning up to that Dave ?
Barrie
#3 Re: Low Oil Pressure solved
Post by abowie » Tue Jun 22, 2021 12:57 am
Easy to do and as a further challenge some gasket kits come with multiple different gaskets.
Dave Dawson
#4 Re: Low Oil Pressure solved
Post by Dave Dawson » Tue Jun 22, 2021 10:55 am
:oops: Err Yes Barrie i must put my Hand up to it, I did not trust the reading on the cars smiths gauge the normal runing pressure was around 45 psi hot , since replacing the gasket this has increased to 48 psi but the idle is steady 25 psi .
Triumph Tr5 pi Tr3a
tinworm
#5 Re: Low Oil Pressure solved
Post by tinworm » Tue Jun 22, 2021 12:56 pm
We all make mistakes! I had low oil pressure on a 3.8 about a month after a rebuild - I stripped out the filter block and found a wire brush bristle on the relief valve seat.
Barrie
Bill B
#6 Re: Low Oil Pressure solved
Post by Bill B » Tue Nov 07, 2023 2:12 pm
:oops: HI Forumites My E-type has had low oil pressure at Hot idle 10 psi since it was rebuilt by my self in 2014 . while Checking over my E-type over,[just before the 60th meet at Shelsey Walsh] i noticed an oil leak from the PRV on the oil filter head, on removing the complete head I found the gasket was fitted back to front, so oil had been leaking past the prv on the LHS, on replacing the gaskets correctly the hot idle pressure increased to 25 PSI [Smiths electrical gauge] .IMG_0459.jpg :oops:
sorry for the old thread, Is this picture of the gasket incorrectly installed?
S1 OTS 4.2 1966
I really go to put this thing back together
#7 Re: Low Oil Pressure solved
Post by mgcjag » Tue Nov 07, 2023 2:38 pm
That's what the first post says....Steve
#8 Re: Low Oil Pressure solved
Post by DWW » Tue Nov 07, 2023 3:02 pm
I think so.
#9 Re: Low Oil Pressure solved
Post by Series1 Stu » Tue Nov 07, 2023 4:23 pm
Yep, definitely reversed.
This design obviously pre-dates the adoption of poka-yoke techniques, etc.
No wonder the Japanese companies kicked our backsides with quality and reliability.
