S1 horn location
phoenix
#1 S1 horn location
Post by phoenix » Thu Jul 29, 2021 4:33 am
Hi. Where should the horns be fitted on a 1965 built but registered 66 car .On the bottom of the picture frame or on the bonnet .Also should the wiring loom from the rear come down one side and join with a block at the rear. Its a bit confusing as it came with both side looms and the joining block.
S1 4.2 RHD Bryan
Robsan
#2 Re: S1 horn location
Post by Robsan » Thu Jul 29, 2021 11:08 am
The horns are fixed with a bracket bolted to the picture frame on either side......................
https://www.sngbarratt.com/English/#/uk ... mbly/21066
For my series 1.5 car, I think two wires from the loom come to LH side cconnector. then a single wire to each horn. The horn has its second connection via a short link to earth on ethe mounting bracket
neal herridge
#3 Re: S1 horn location
Post by neal herridge » Thu Jul 29, 2021 3:55 pm
Some 1965 cars had the horns in the bonnet .
caveman
#4 Re: S1 horn location
Post by caveman » Thu Jul 29, 2021 7:11 pm
My May 65 build has the horns mounted on the underside of picture frame.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#5 Re: S1 horn location
Post by bitsobrits » Fri Jul 30, 2021 12:47 am
My early 65 car (sorry, don't remember the month of build-March?) has the horns in the bonnet.
phoenix
#6 Re: S1 horn location
Post by phoenix » Fri Jul 30, 2021 12:59 pm
I have now fitted them on to the picture frame as the feed to the horns is not in the loom to the bonnet . Problem solved .
S1 4.2 RHD Bryan
