Changing map location
Mark Gordon
#1 Changing map location
Post by Mark Gordon » Thu Sep 16, 2021 4:39 pm
This past summer, I moved from Virginia to Ohio (about 450 miles). My Zee Maps world location needs to be changed but I can't figure out how to edit my location. Can anyone give directions to this Luddite?
#2 Re: Changing map location
Post by mgcjag » Thu Sep 16, 2021 4:46 pm
Click on your avatar at top of page......User control panel. ....profile.....edit location....Steve
Mark Gordon
#3 Re: Changing map location
Post by Mark Gordon » Thu Sep 16, 2021 9:09 pm
Thanks, Steve. I forgot to change my E Type Forum address too (now done), but what I still need to do is change my location on the Zeemaps world map of E Types
Much appreciated,
#4 Re: Changing map location
Post by PeterCrespin » Fri Sep 17, 2021 1:59 pm
Much appreciated,
I think you just do a screen grab, print out the map, cut the bit out showing your E-Type in Virginia, and stick it over the bit showing Columbus, Ohio. Then you color in the hole in Burke, Va., take a photo of the new map and paste it over the current incorrect screen. Easy-peasy Mark.
Pete (Luddite #2)
Stuart Exelby
#5 Re: Changing map location
Post by Stuart Exelby » Fri Sep 17, 2021 3:31 pm
Steve / Mark - did you mean the actual map - rather than the location? I think I remember when I loaded my map location originally I was supposed to note a code which represented the pinpoint.... and would then be able to alter it. But of course, I didn't note it, or lost the note, or whatever..... and no longer have access to the e-mail I had at the time either!! Doh!! So I think I will be forever on the map where I was when I first bought the car..... :cry:
1967 Series 1 OTS
#6 Re: Changing map location
Post by mgcjag » Fri Sep 17, 2021 6:23 pm
Hi.....dont know much about the map...havent used it in years....forum info here http://forum.etypeuk.com/viewtopic.php? ... 88e7155994 is there anything stopping you just starting again and adding yourself as a new E type...rather than try to change your existing?......Steve
Stuart Exelby
#7 Re: Changing map location
Post by Stuart Exelby » Fri Sep 17, 2021 6:41 pm
Steve - it occurred to me that was the only option.... it just didn't seem right ....... But yes, think I will have to! There will be one more S1 OTS in the world...... yay! :bouncyyellow:
1967 Series 1 OTS
Mark Gordon
#8 Re: Changing map location
Post by Mark Gordon » Fri Sep 17, 2021 7:50 pm
I went to the link that you provided, Steve, and noted that David stated IN RED LETTERS to bookmark or write down the URL that would be provided upon first listing my location. Of course, I failed to do so, so I guess that I'll forever reside in Burke, VA. Thanks for the info from the President of Luddites International.
