3.07 diff vs O/D box
Paul bow
#1 3.07 diff vs O/D box
Post by Paul bow » Tue Sep 21, 2021 8:45 am
Looking for a bit of knowledge here guys..
Annoyingly I had my diff rebuilt and did not change the ratio, being a USA car it runs 3.54. Great fun but not so much on a motorway, so this winter I’ve a dilemma, do I change the ratio to a 3.07 and may be do a little work on the head to give a bit more power to compensate the slower initial drive or remove the engine and box and put an OD unit on it.. I’m not in the market of 7/8k 5 speed box’s unfortunately.. anyone views would be gratefully received.
Many thanks 👍
S1 2+2 manual. (Sold)
#2 Re: 3.07 diff vs O/D box
Post by abowie » Tue Sep 21, 2021 8:54 am
That's a good start.
I have a 4.2 S1 car with a 3.07 diff and it is fine given that I'm limited to 100kph here.
#3 Re: 3.07 diff vs O/D box
Post by mgcjag » Tue Sep 21, 2021 9:01 am
If its for your ots you will struggle to fit an o/d without butchering the car..read up about 2.88 diff.....Steve
#4 Re: 3.07 diff vs O/D box
Post by abowie » Tue Sep 21, 2021 9:02 am
It's a 2+2.
#5 Re: 3.07 diff vs O/D box
Post by mgcjag » Tue Sep 21, 2021 9:10 am
Ah yes the ots was previous.....lots of info on the forum if you search 5 speed options...once you get to 70mph on a 3.07 you will probably have liked another gear..you cannot add an o/d you will need another box with o/d..Steve
lowact
#6 Re: 3.07 diff vs O/D box
Post by lowact » Tue Sep 21, 2021 9:25 am
I'm doing both, 3.07 and O/D. From 3.54 (S3)
Paul bow
#7 Re: 3.07 diff vs O/D box
Post by Paul bow » Tue Sep 21, 2021 9:30 am
Ok.. so def start with the 3.07 and being a 2+2 prob do the Gbox as well with the compact OD unit, yes that actually sounds like a winning formula, with the exception of having to drop the engine out .. but at least it’ll be an excuse to get the spanner’s out again whilst it’s hauled up in winter.. cheers guys 👍
