Fuel
#1 Fuel
At a recent classic car event a guy suggested that adding a small amount of 2 stroke oil to the E5 petrol creates a better and fuller burn . Anyone heard this before and does it improve performance ?
1972 OTS
Opalescent silver blue
Purchased Oct 2020
Purchased Oct 2020
#2 Re: Fuel
Not heard of this but people used to drop a bit of Castrol R into the fuel to get that genuine “racer” smell!
#3 Re: Fuel
Redex anyone?
#4 Re: Fuel
Unlikely to improve the burn. 2 stroke oil is intended not to burn well so it lubricates the engine...probably all you will get is blue haze. Interestingly in this week's classic car weekly there is a piece by Fuzz Townshend and he subjectively thinks his pre war Austin ran better on E10 than E5.
Don't forget that E10 means up to 10% ethanol. All the pump marks were changed on Sept 1st but chances are a lot of fuel is still E5 until the petrol station is refilled and the existing base stock in the system becomes E10....I suspect a lot.of what is sold as E10 now is probably still E5....probably by Oct it will be approaching E10....
#5 Re: Fuel
Can you still buy Redex…..I have an original Redex gun that my Grandfather had at his garage petrol pumps. 1 squirt per gallon of petrol, if I remember right. A good suggestion if you can still buy it.
#6 Re: Fuel
I have certainly bought redex within the last 3 or 4 years - it came from most accessory stores in 500ml or 1 litre bottles
#7 Re: Fuel
“A shot of redex, sir?” Something from the distant past. A bit like sitting in the barbers and hearing “anything for the weekend, sir?”
#8 Re: Fuel
Redex (RTM) and all sorts of other potions are readily available...
AussieEtype
#9 Re: Fuel
The idea of putting 2 stroke oil in the duel comes from modern common rail diesels with tight tolerance high pressure injection pumps. These pumps have extremely high tolerances and are lubricated buy the diesel - they cannot handle any impurities in the fuel like water and if the pump looses lubrication if fails.'
The logic is that the 2 stroke oil provides additional lubrication for the pump, particularly with low sulphur diesel and if it sucks in a sip of water the 2 stroke may provide enough lubrication for the high pressure fuel pump to survive the event.
Garry
Garry
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
OttoDachs47
#10 Re: Fuel
My Wife’s BMW Mini Cooper seems to run better on E10. The engine definitely feels more flexible.
Ian.
Ian.
