Ignition switch rubber cable shroud C26851
Monkeyfinger
#1 Ignition switch rubber cable shroud C26851
Post by Monkeyfinger » Mon Sep 27, 2021 10:03 am
Just popping onto this board to see if any S3 owners can confirm if the ignition switch rear cable rubber shroud I have a thread about on the S2 board is likely to fit the switch on an S3? The Jag part number is as above, but I don't have any relevant S3 information to be able to confirm if this was a common part or even used on S3 cars.
Bob.
#2 Re: Ignition switch rubber cable shroud C26851
Post by Bob. » Mon Sep 27, 2021 12:09 pm
Same part number used on S3. (you can access the Parts Manuasl in the Forum Knlowledge Base)
Bob
'71 S3
Monkeyfinger
#3 Re: Ignition switch rubber cable shroud C26851
Post by Monkeyfinger » Mon Sep 27, 2021 1:59 pm
Great stuff - thanks Bob
Bob.
#4 Re: Ignition switch rubber cable shroud C26851
Post by Bob. » Mon Sep 27, 2021 4:14 pm
Sorry, I should have said only early S3s with the Britax switch used C26851, not later cars which have the WASO switch.
Bob
'71 S3
