Am wondering if someone can help pls ?
I am well into the restoration of my 1961 Flat Floor car and have come across the following
The bottom inlet hole in the air intake box on my 3.8L car is off center of the air filter canister by around 20mm. So it appears either the trumpet length is too long or, the inlet in the fibre-glass airbox is incorrected located
I am not sure if either the trumpet piece or the airbox item is original - so I guess it could be either in error and I need eliminate one of the two possibilities
Can I ask pls if someone with a 3.8L car can confirm the length of their trumpets. Pls note mine measure approx 80mm as per the pic attached
With the above information I hope to be able pin-point the problem to the trumpet length or dimensions of the airbox construction
Tony
