new owner 67 basket case
autoalain
#1 new owner 67 basket case
Post by autoalain » Sun Feb 06, 2022 2:21 pm
Folks, bought a rough one, e type, looking for a shop/restoration manual/book, going to need a
lot of help from a book, which one should I buy, keeping price in mind. will add pic.
tim wood
#2 Re: new owner 67 basket case
Post by tim wood » Sun Feb 06, 2022 4:19 pm
So many books available. Maybe the one by Chris Rooke who rebuilt a series 2 mostly at home.
#3 Re: new owner 67 basket case
Post by Series1 Stu » Sun Feb 06, 2022 4:19 pm
The cost of books is nothing in comparison to the cost of spares! There are lots of good books available, some by people that contribute to this forum, such as Peter Crespin.
The Jaguar service manual and spare parts catalogues are essential to have by you throughout. A good originality guide, such as the one by Haddock, which is back in print, is also essential reference material.
The Jaguar manuals are reproduced here on the forum and can be downloaded in pdf format.
As for restoration guides, there are several blogs around with very variable quality of work and presentation and it is always worth getting a cross-fix from 2 or more places.
Finally, this forum is your best friend for advice, guidance and encouragement throughout the process. There is so much skill and experience on offer.
Good luck with your project and put your name and car model in your signature box so we can all address you politely and know what you are referring to when asking questions.
#4 Re: new owner 67 basket case
Post by mgcjag » Sun Feb 06, 2022 4:41 pm
As mentioned above.....this Chris Rooke book is very good.....and will give you a good understanding.....you should be able to find decent second hand copies and check ebay.....Steve
#5 Re: new owner 67 basket case
Post by Gfhug » Sun Feb 06, 2022 6:29 pm
And if you plan to change to RHD there’s a very good write up in the knowledge section.
How much work do you plan to do? All or farm out some to others? If so then be very careful who you use. Companies go bust, do bad work because they don’t understand the E Type and let you down. As Stu says, this forum is invaluable and asking questions here will be a good start as will using the search function.
Good luck
Jeremy
#6 Re: new owner 67 basket case
Post by Jeremy » Sun Feb 06, 2022 6:59 pm
All the above. And Chris Vine's blog. Plus I found this book - an account of a restoration at CMC - quite helpful:
https://books.google.co.uk/books/about/ ... edir_esc=y
Jeremy
1967 S1 4.2 FHC
Kember17
#7 Re: new owner 67 basket case
Post by Kember17 » Sun Feb 06, 2022 7:49 pm
+1 to that book.
As for your budget, as someone who discovered his Series 1 was riddled with bodged work and rust, I suggest working out what you think is sensible. Then double it and then double it again. Then do the same for timetable…
In the world of investment appraisal, this aims off for the phenomenon known as optimism bias!
Peter
1966 LHD US Import Series 1 2+2 (undergoing full restoration)
1991 LHD Alfa Spider Series 4
2015 Porsche Panamera S
Jeremy
#8 Re: new owner 67 basket case
Post by Jeremy » Sun Feb 06, 2022 9:16 pm
:yeahthat:
Jeremy
1967 S1 4.2 FHC
eddiecross
#9 Re: new owner 67 basket case
Post by eddiecross » Mon Feb 14, 2022 1:56 pm
Getting to know Chuck and his bodywork panels, advice and you tube posts would be a great start.
https://www.monocoque-metalworks.com/main/
Good Luck
Eddie
67 FHC
67 FHC
tinworm
#10 Re: new owner 67 basket case
Post by tinworm » Mon Feb 14, 2022 6:07 pm
Thats not rough - I would have driven that home ! ...
Barrie
PS a long journey awaits - some of us know all about it
