e type valuation
#1 e type valuation
Help!!
I have inherited an e-type, first registered in1970.
It has been sitting in an outhouse for the last 40 years and is a major restoration project.
Or needs to be sold for spares.
I need to find it a good home but I need to put a realistic price on it.
How do I go about getting it valued?
I really need help with this!!
#2 Re: e type valuation
Hi...he need photos to help you......Steve
#4 Re: e type valuation
Hi......in my opinion it would be best put on ebay on auction.....most important do you have the registration documents......this would increase its value....Steve
#5 Re: e type valuation
A RHD 2+2 ?
Barrie
Barrie
#6 Re: e type valuation
If it's a 2+2, I doubt if any restorer would get his money back at the end. Salvageable spares is probably the best option I would have thought.
#7 Re: e type valuation
#8 Re: e type valuation
Looks like a S2......but not a 2+2......the panel in front of the windscreen is too wide....the S2 2+2 bonnet comes up very close to windscreen.........Steve......
#9 Re: e type valuation
If its a coupe RHD with docs £25K I'd say if 2+2 £16K - but photos too small and I cannot open them larger - The car would need a restorable bodyshell.
Now you have to get that money ! Not as easy as you think.
Barrie
Barrie
#10 Re: e type valuation
Ah, yes, Steve, you are correct. Curious, though , that it should be 1970 registered and not an S2
#11 Re: e type valuation
Isn’t it an S2? Looks like one in the photo on the back of the lorry, although the photo is very poor and tiny. In the condition I would have thought more like 15k, maybe 20k if very lucky.
Darryl
#12 Re: e type valuation
It's very peculiar, because I think Steve is correct about its not having the S2 windscreen which goes far forward in the centre, and yet as you say ( although the pic is very small ) the rear end looks like an S2. Could be a bitsa car which only makes things worse
#13 Re: e type valuation
Just to confirm...i think this is a S2 fhc......and not a 2+2........the scuttle panel in front of the windscreen is much wider than on a S2 2+2...and looks like 3 wipers...... also you can see the clutch/brake and expansion reservoirs on right hand bulkhead.....Steve
#15 Re: e type valuation
Definitely a 2 seat coupe.
Barrie
Barrie
#16 Re: e type valuation
Hi...yes as i mentioned above its a 4.2 S2 fhc......just to give you a comparison. ..this is currenlty on ebay..it shows some rot/rust....so probably more hidden.....your has all the rot on show and.....to get it to the condition of the ebay car would cost £60k plus.......as i mentioned in my first post.....put it on auction on ebay.....it will sell but dont get confused thinking..E type ££.......Steve https://www.ebay.co.uk/itm/Jaguar-E-Typ ... ect=mobile
#17 Re: e type valuation
Thanks for your input!
Any suggestions as to what reserve I should set on ebay?
Don't want to lose it for a tenner!
#18 Re: e type valuation
Post more photos...interior....inside boot etc......Steve
#19 Re: e type valuation
Ok.
Will get that sorted.
Thanks again.
Thanks again.
