Early vs late upper a arms.
Geoff Allam
#1 Early vs late upper a arms.
Post by Geoff Allam » Fri Feb 25, 2022 9:39 pm
I am working on the front suspension of my late 67 ots and have discovered that I have one a arm with the grease zerk on the side of the ball mount as in earlier cars, and one with the later arrangement with the zerk in the top cap. I have received an opinion on the jag lovers list that the early and late arms may not be interchangeable and I may not be able to just plug the zerk hole and put in a zerk in the top cap. Does anyone have experience with this problem. I have posted the same question on jag lovers.
Geoff Allam
#2 Re: Early vs late upper a arms.
Post by abowie » Fri Feb 25, 2022 10:10 pm
The upper ball joint repair kit from SNGB is listed as suitable for all E types from 3.8 to Series 3 so I don't think you 'll have a problem.
Geoff Allam
#3 Re: Early vs late upper a arms.
Post by Geoff Allam » Sat Feb 26, 2022 5:28 am
Thank you Andrew. That was my conclusion after comparing the measurements of each. I did want to check because the person who suggested there might be a problem is generally extremely accurate.
Geoff Allam
tinworm
#4 Re: Early vs late upper a arms.
Post by tinworm » Sun Feb 27, 2022 8:56 am
You can fabricate the top plate without a hole using steel of the same gauge - if you want the earlier look.
Barrie
Geoff Allam
#5 Re: Early vs late upper a arms.
Post by Geoff Allam » Sun Feb 27, 2022 5:02 pm
Thank you Barrie but I have top plates both with and without the hole. As an aside I have a couple of the A&A engraved ones from very early cars. Not sure if they are of any value.
Geoff Allam
splosh
#6 Re: Early vs late upper a arms.
Post by splosh » Thu Mar 03, 2022 2:17 am
Hi Geoff,
I would like one of your A&A top plates if you are willing ?
Let me know what you would like for one and postage to the U/K.
Clive
Clive
August 1961 Flat floor ots
Geoff Allam
#7 Re: Early vs late upper a arms.
Post by Geoff Allam » Thu Mar 03, 2022 3:17 am
Thanks for the interest Clive but I will be saving the plates to use on my 3.8 next time I reshim the ball joints. It has just standard aftermarket ones now. The A&A plates just happened to be in a lot of misc bits I purchased and I was quite pleased to find them.
Geoff Allam
