Choke lever mechanism: series 2 FHC
skodajag
#1 Choke lever mechanism: series 2 FHC
Post by skodajag » Tue Mar 22, 2022 1:19 pm
The choke lever on my car is missing the mechanism which holds it in the on positions. Can anyone direct me to an exploded view of the lever mechanism so I can see what's missing?
Thank you.
Jonathan
Series 2 FHC, 1968
#2 Re: Choke lever mechanism: series 2 FHC
Post by DWW » Tue Mar 22, 2022 1:31 pm
JerryL770
#3 Re: Choke lever mechanism: series 2 FHC
Post by JerryL770 » Thu Mar 24, 2022 1:26 am
Hi Jonathan,
I'm not sure if you found that diagram to be helpful or not as it shows S1 and 2 mechanisms and is unclear about separation. I've marked up the diagram with some info.
I took some aid memoir pictures of my mechanism whilst working on its restoration. I hope these may help some.
Lever drwg.jpg (168.16 KiB) Viewed 5854 times
Jerome Lunt
JerryL770
#4 Re: Choke lever mechanism: series 2 FHC
Post by JerryL770 » Thu Mar 24, 2022 1:28 am
Only 3 pictures per post allowed now so here's 2 more.
I hope this helps some.
Jerome Lunt
61Elite
#5 Re: Choke lever mechanism: series 2 FHC
Post by 61Elite » Fri Mar 25, 2022 1:54 pm
Here is a page from the S3 parts manual. I have a S2 and a S3. the controls are the same. The only difference is the S2 has a single cable to the carbs and the S3 has two cables (one to each side). I hope this helps.
