Cause?
Possibly high alternator output?
Regulator issues ?
It is a Flamethrower coil and ignition with a new direct wire lead from ignition switch which is on a relay and fused at 5 amps ( not the wire just the switch )
I understand that anything over 14.5 volts may over heat the coil
Any advice much appreciated
Keith
