Knock off Wheel Spinners
Majorpidge
#1 Knock off Wheel Spinners
Post by Majorpidge » Sun May 01, 2022 8:18 am
Morning Chaps & Chapesses
This is the first time that I’ve owned a classic and one with knock off wheel spinners. I am concerned that having no experience with these in the event of having to remove the wheel, can I do it competently and safely. I do not fancy using a soft hammer in case I hit the paintwork in the process. I am a little clumsy with this type of thing. I’ve bought a removal tool from Limit Engineering as pictured and I plan to buy a cheap torque wrench to put in the spare wheel recess along with the Jack and spinner tool. I’ve heard different opinions on how tight the spinners should be fitted. My question is this, is there such a thing of a torque setting I should be aiming for. Do these thing ever come loose?
Deryk
E-Type Series 1.5 2+2 Coupe 1968
#2 Re: Knock off Wheel Spinners
Post by mgcjag » Sun May 01, 2022 8:48 am
Hi Deryk...have a read here.......tightening spinners isnt a real problem. ....undoeing them however can be difficult with a spinner tool/bar etc.....a good heavy hammer and a length of 4x2 will always get you out of trouble..Steve viewtopic.php?f=3&t=12794&hilit=Spinner+torque
Majorpidge
#3 Re: Knock off Wheel Spinners
Post by Majorpidge » Sun May 01, 2022 12:18 pm
Thank you. That explained it perfectly. There’s some smart cookies here!!! :thankyouyellow: :thankyouyellow:
Deryk
#4 Re: Knock off Wheel Spinners
Post by Gfhug » Sun May 01, 2022 1:17 pm
Does anyone know if Lionel is still making his spinner tools? Wouldn’t mind getting another for the federal spinners.
#5 Re: Knock off Wheel Spinners
Post by rswaffie » Sun May 01, 2022 1:32 pm
He was still doing them in Sept 2020 as that’s when I bought mine.
caveman
#6 Re: Knock off Wheel Spinners
Post by caveman » Sun May 01, 2022 2:17 pm
He was still pushing them out last year, here’s his contact details and a lovely chap to do business with;
Mr Lionel Roberts
wheelwidget@hotmail.com
Cjservices1931@aol.com
1965 S1 4.2 FHC (early)
:wavegreatbritain:
mtnjag
#7 Re: Knock off Wheel Spinners
Post by mtnjag » Sun May 01, 2022 3:00 pm
What do they look like?
Anyone have a pict?
So that Limit Eng tool just puts the pegs on either side of the knock off ears and turn with wrench?
Does it work well?
Utube looks easy peasey
Layne
Car #876005, 62 OTS
Majorpidge
#8 Re: Knock off Wheel Spinners
Post by Majorpidge » Sun May 01, 2022 3:09 pm
I’ve no idea…. I haven’t tried it yet. I will have a go with it tomorrow
Deryk
#9 Re: Knock off Wheel Spinners
Post by mgcjag » Sun May 01, 2022 3:15 pm
Video clip here.....think you will need the impact hammer looking at the design....will be awkward applying pressure with the extension shaft comming out of the tool......Steve https://shop.limitfabrications.co.uk/?p ... inner-tool
mtnjag
#10 Re: Knock off Wheel Spinners
Post by mtnjag » Sun May 01, 2022 3:38 pm
Yes, funny the video shows it with an impact. On the road is where it would be most helpful. Be good to have an "on the road" simulation of it in action without an impact.
Layne
Car #876005, 62 OTS
#11 Re: Knock off Wheel Spinners
Post by DWW » Sun May 01, 2022 3:46 pm
I use this one....bought it for a tenner at some show....
https://www.ebay.co.uk/itm/265244165167 ... qTEALw_wcB
mtnjag
#12 Re: Knock off Wheel Spinners
Post by mtnjag » Sun May 01, 2022 3:49 pm
I had that one. Used it one time and it delaminated and pounded apart. Has yours held up?
And of course you're still using the hammer.
Layne
Car #876005, 62 OTS
#13 Re: Knock off Wheel Spinners
Post by Gfhug » Sun May 01, 2022 4:21 pm
Layne, see if Lionel (see above) will ship stateside. They are very good and maybe there’s an American equivalent?
#14 Re: Knock off Wheel Spinners
Post by DWW » Sun May 01, 2022 5:11 pm
mtnjag wrote: ↑
Yes no problems with mine still in one piece and works well with the original hammer that came with the car.
mtnjag
#15 Re: Knock off Wheel Spinners
Post by mtnjag » Sun May 01, 2022 5:21 pm
Thanks Geoff,
Yes like to check it out. Haven't missed with the hammer yet but I'm not getting any steadier.
Layne
Car #876005, 62 OTS
#16 Re: Knock off Wheel Spinners
Post by DWW » Sun May 01, 2022 5:25 pm
:bigrin:
JerryL770
#17 Re: Knock off Wheel Spinners
Post by JerryL770 » Wed May 04, 2022 6:40 pm
I bought one of Lionel's tools. Nice tool but I don't carry it 'cos I cannot undo my spinners with it (when they are done up good and tight). This is because you need a v. large socket/spanner to fit the hex and it all takes up too much space. I use the nylon faced Thor hammer. It's heavy enough and does not mark the spinners. Copper mallets will mark the spinner.
Jerome Lunt
dlgis
#18 Re: Knock off Wheel Spinners
Post by dlgis » Wed May 04, 2022 7:41 pm
Just to say Lionel is definitely still making his spinner tool, I bought one a couple of weeks back. Here’s a pic. I had to buy a 38mm socket but I already had a reasonable sized bar to use with it.
Darryl
#19 Re: Knock off Wheel Spinners
Post by Gfhug » Wed May 04, 2022 8:24 pm
Jerry, it isn’t difficult to fit a long extension bar and 38mm (or is it 39mm) socket lying across the car behind the upstand. It’s where I keep mine and if it’s a bit tight to undo simply stand on the end of the long socket extension and it soon comes undone. I hope that helps.
