Cooling Fan
Ian Cooke
#1 Cooling Fan
Post by Ian Cooke » Mon Aug 15, 2022 7:52 pm
Hi all
My Series 2 has a single Kenlowe Fan which will often continue running for up to 10 minutes after the ignition has been switched off. Is this normal / necessary as it must result in a significant drain on the battery?
Thanks for any advice
Ian
Ian Cooke
1969 S2 FHC in Old English White
#2 Re: Cooling Fan
Post by DWW » Mon Aug 15, 2022 8:36 pm
Looks like the fan relay wiring is incorrect. On S! the relay is connected to fuse No 6.
#3 Re: Cooling Fan
Post by abowie » Mon Aug 15, 2022 11:11 pm
Or it's just been wired directly to the battery.
johnetype
#4 Re: Cooling Fan
Post by johnetype » Tue Aug 16, 2022 12:27 am
It is normal depending on how the Kenlow fan has been wired - as Andrew suggests.
If it only runs for 10 mins or so the drain on the battery is insignificant.
The highest temperature the engine and cooling system will routinely see is in the few minutes after the engine is stopped which is why the Kenlow is cutting in and will help limit that rise.
1969 Series 2 FHC
#5 Re: Cooling Fan
Post by abowie » Tue Aug 16, 2022 1:37 am
Will it if there's no coolant flow through the engine?
Ian Cooke
#6 Re: Cooling Fan
Post by Ian Cooke » Tue Aug 16, 2022 7:48 pm
Many thanks for your responses.
It sounds as though the fan running on after the ignition has been switched is ok but what i'm not clear on is whether there is any need or benefit to it doing so.
Do other fans continue to run when the engine has stopped or is it just the Kenlow that has this feature?
Ian Cooke
#7 Re: Cooling Fan
Post by MarekH » Tue Aug 16, 2022 8:10 pm
....and will help limit that rise.
As Andrew points out, with no water circulation, it won't do very much at all.
To make it effective, see
https://forums.jag-lovers.com/t/solving ... ple/377151
Look at the dark blue line. This is the temperature at the bottom of the radiator. When the fan cuts in, a nice pool of cold water is generated, but none of it is useful until it is swapped with the hot water sitting in the cylinder heads. That is achieved by running the engine for no more than 45 seconds. That cools the engine a lot, whereas just running the fan achieved pretty much nothing. It's all there on the graph in black and white.
