Hefferon
Post
by Hefferon » Thu Sep 29, 2022 10:30 am
Hello forum - I am restoring a 1966 2+2 and want to retain my original growler horn push but the chrome retaining ring was in a bad way so I lifted the tabs to remove it and you know it - the tabs broke off!
The part is apparently 54300576 (originally made by Lucas - see below) but I can't find anywhere to buy a replacement ring. Reproduction horn push complete units are available of course but I just need the ring so it seems bonkers to buy a whole unit just to harvest the ring.... and then there is every chance it might break again while doing the swap.
Does anyone know how I can source this ring or have any ideas how I might repair the tabs?
Many Thanks
- Administrator
Post
by Heuer » Thu Sep 29, 2022 2:22 pm
I butchered a repro horn push to get the chrome ring for mine. It fits perfectly.
Hefferon
Post
by Hefferon » Thu Sep 29, 2022 6:11 pm
Many Thanks - I fear this might end up being the only option but had hoped I might be able to track down the repo maker and buy the ring. It is so frustrating when Google doesn't have the answer because everything I have ever needed to buy or research has been at my fingertips so far...thank goodness.
The car isn't ready for the road just yet so will keep looking for a while longer
- Moderator
Post
by mgcjag » Thu Sep 29, 2022 6:26 pm
Cant remember the details of the assembly.....cant you epoxy the ring in place.....or epoxy on a couple of small tabs?.....Steve
Hefferon
Post
by Hefferon » Thu Sep 29, 2022 6:52 pm
hi Steve
I was looking at that today.... I don't think gluing the tabs back will work because I could only do it on the very thin edge of the metal so once they were bent I am certain they wouldn't hold. I can't glue them on the inside of the ring where there is more surface area because this would fail the growler push (needs to move up and down of course) unless I take a file to my original badge. I can't glue them on the outer edge because there is no space to take even a 1mm tab really without forcing it a bit and risking it then fouling the push.
Gluing the ring in place might be the only option to avoid buying a new repo horn push just to use the chrome ring. That said another £100 is a drop in the ocean just don't tell my wife that!
I might try a very strong steri-strip or 3.... doesn't feel right when I have tried to meticulously put this car back together properly. If this doesn't work, I will epoxy it in the surround as you suggested.... Many Thanks
- Moderator
Post
by mgcjag » Thu Sep 29, 2022 7:09 pm
How about not just a tab but a tee shape tab (larger bar at top) or......Braze/solder new tabs.....if it discolores the chrome re chrome it...or try chrome spray ...iv used it on small items and had gread results........or diy nickle plate and polish it.....Steve
Hefferon
Post
by Hefferon » Thu Sep 29, 2022 7:18 pm
I will try the braze/solder approach… there is only a very small edge that shows so doubt a bit of discolouration will be a problem. Fingers crossed. Cheers
Post
by DWW » Tue Oct 11, 2022 9:43 pm
Sent you a pm.
