However a recent topic I started in the technical section to give ready reference for how to wire lock bolts has been an example of the daily work he does to keep this forum in good order.
All I had done was plagiarise info from the interweb, David then had to format it all to the forum standard, tidy up some of my headings and generally make it all easier on the eye. He will then probably convert it to pdf to add to the KB and make the topic a sticky. Mine was the easy job, his the more onerous.
Which leads me to say a public thank you, David, for the back room work you do for all our benefits
With gratitude
