Changing contact breaker points
Piscator
#1 Changing contact breaker points
Post by Piscator » Tue May 16, 2023 9:44 pm
Today I changed points and condenser. Every time I do this, I worry that I will drop a screw down the inside of the distributor.
What do forum members do to reduce this risk?
1. Use a magnet.
2. Cover gaps with a cloth
3. Use thick grease on the screwdriver
4. Fit electronic ignition
5. Any other suggestions?
I used a combination of method 2 (the cloth) and method 3 (the grease), but I still wasn't totally confident....
Many thanks in advance for your advice.
John L
1969 S2 OTS RHD
#2 Re: Changing contact breaker points
Post by DWW » Tue May 16, 2023 10:09 pm
Electronic here makes it all pointless :bigrin:
#3 Re: Changing contact breaker points
Post by mgcjag » Wed May 17, 2023 7:31 am
Note the rotor arm position in the dizzy....slacken the dizzy clamp nut.....pull out the dizzy.....then take it to the bench to fit the points...or by the side of the road....refit..easy.....Steve
Piscator
#4 Re: Changing contact breaker points
Post by Piscator » Wed May 17, 2023 8:40 am
Brilliant, simple, easy when you know how. I'll do it that way next time.
Many thanks, Steve
John L
1969 S2 OTS RHD
