Ignition vacuum
#1 Ignition vacuum
Post by DWW » Thu Jun 08, 2023 4:01 pm
Just trying to make sure all is correct, is the vacuum to advance the ignition pulled from SU No3?
mtnjag
#2 Re: Ignition vacuum
Post by mtnjag » Thu Jun 08, 2023 4:23 pm
My 62 it's from the front carb above the distributor
Layne
Car #876005, 62 OTS
caveman
#3 Re: Ignition vacuum
Post by caveman » Thu Jun 08, 2023 4:28 pm
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#4 Re: Ignition vacuum
Post by DWW » Thu Jun 08, 2023 5:16 pm
Lovely, thanks yes I have that only that at some point in the car's past the copper tube was cut around an inch and a half past the bend from the carb and a fabric braided rubber hose was fitted. I guess I will get the proper one some day.
On the other hand at £51.85 its a bit of a liberty.
caveman
#5 Re: Ignition vacuum
Post by caveman » Thu Jun 08, 2023 5:55 pm
If I was a betting man, I’d say this is same :fingerscrossed:
:wavegreatbritain:
caveman
#6 Re: Ignition vacuum
Post by caveman » Thu Jun 08, 2023 6:02 pm
Martin Robey :bouncyyellow:
:wavegreatbritain:
#7 Re: Ignition vacuum
Post by DWW » Thu Jun 08, 2023 6:05 pm
caveman
#8 Re: Ignition vacuum
Post by caveman » Thu Jun 08, 2023 7:46 pm
:wow:
I don’t have the loop in mine and no affect noted in 23yrs.
:wavegreatbritain:
#9 Re: Ignition vacuum
Post by DWW » Fri Jun 09, 2023 11:40 am
Thanks all, under consideration....
Allrand
#10 Re: Ignition vacuum
Post by Allrand » Fri Jun 09, 2023 12:02 pm
My '64 has the rubber connecting pipe to the carb. Seems earlier cars had the screw down fitting on a coiled pipe as shown in the top pic, similar to my old Mk7.
Randall Botha
#11 Re: Ignition vacuum
Post by DWW » Fri Jun 09, 2023 12:07 pm
My distributor vacuum nozzle has no thread just a push on fit for a hose.
mtnjag
#12 Re: Ignition vacuum
Post by mtnjag » Fri Jun 09, 2023 12:48 pm
Yep, my 62 is the threaded connection. I thought all 3.8s had a carb with that setup.
Do you have the original 3.8 type intake?
Perhaps a replacement carb?
Layne
Car #876005, 62 OTS
caveman
#13 Re: Ignition vacuum
Post by caveman » Fri Jun 09, 2023 2:40 pm
:yeahthat: Mine too yet original 1965 4.2.
The Factory Original Guide Jaguar E Type (Anders Ditlev Clausager) doesn’t indicate rubber hose either way.
:wavegreatbritain:
#14 Re: Ignition vacuum
Post by DWW » Fri Jun 09, 2023 3:08 pm
Yes all original engine and carbs, the carbs do have the standard threaded bit and the copper pipe is 3" long angled at 90 degrees but the distributor has a slip on type nozzle. the rubber hose is slipped over the copper pipe on the carb and the other end over the distributor vacuum nozzle. it all works fine.
