Series 3 Clutch Master Cylinder
rkellogg19
#1 Series 3 Clutch Master Cylinder
Post by rkellogg19 » Thu Aug 17, 2023 11:36 am
Has anyone used the Wilwood master cylinder for the clutch in a Series 3? Part #260-6089 is what I have found others have used but it was on earlier cars.
I assume the spacer C31725 and pushrod 12276 would need to be used as well.
Appreciate any advice or experience.
I posted this as well on JL but didn’t get any replies.
Thanks.
Rob
1962 OTS and 1971 V12 2+2
#2 Re: Series 3 Clutch Master Cylinder
Post by mgcjag » Thu Aug 17, 2023 12:47 pm
Hi Rob.....basically i dont know.....but if i use aftermarket parts i get all the dimensions thread sizes and if possible ask the tech support of the supplier if its a compatable fitting.....when it arrives i then compare carefully what i have to the one im replaceing........Steve.....ps you only posted a day ago on JL....if no answers in a few days then bump it up.....but the S3 audience is much smaller than the S1/S2..on there and here.....Steve.....ps re the spacer and pushrod.....if the willwood is identical then yes....if its different then your call
rkellogg19
#3 Re: Series 3 Clutch Master Cylinder
Post by rkellogg19 » Thu Aug 17, 2023 1:13 pm
Thanks. I’m converting auto to manual as part of the restoration so I have nothing to compare it to unfortunately.
Rob
tim wood
#4 Re: Series 3 Clutch Master Cylinder
Post by tim wood » Thu Aug 17, 2023 2:54 pm
You may have seen my thread on using the Wilwood cylinder. I have no knowledge of series 3 but on looking at the SNG parts listing it seems that they list the identical master cylinder for most models including S3
rkellogg19
#5 Re: Series 3 Clutch Master Cylinder
Post by rkellogg19 » Thu Aug 17, 2023 3:37 pm
Thanks Tim - yes I did see your thread. I also saw that they list the same one but just wanted to see if there was any experience out there. I’ll probably give it a go and report back.
Rob
