Brake Fluid
rayloud@outlook.com
#1 Brake Fluid
Post by rayloud@outlook.com » Sat Aug 19, 2023 10:09 am
Hi All, just wondering if any of you lovely people can help? I have an odd problem. I keep getting a leak from the passenger side brake fluid bottle on my 1966 S1. What happens is that the fluid from the driver's side seems to travel to the passenger side botte after a few drives. So the driver's side level lowers and the passenger side bottle fills. I have to take a syringe and transfer it back. I think the leak is caused by the passenger side bottle overfilling and forcing its way out of the top. Has anyone heard of this before?
Many thanks. Ray
tim wood
#2 Re: Brake Fluid
Post by tim wood » Sat Aug 19, 2023 11:00 am
A search of the forum will show threads on this. Usually I believe associated with problems in the cylinder affixed to the servo.
Assume the the total volume of fluid doesn’t change- just transfers ?
rayloud@outlook.com
#3 Re: Brake Fluid
Post by rayloud@outlook.com » Sat Aug 19, 2023 3:07 pm
Hi Tim
Many thanks. What search words will bring up those links? Ray
#4 Re: Brake Fluid
Post by Gfhug » Sat Aug 19, 2023 3:48 pm
Try searching for “servo” then search the results for “transfer”.
You will find results that talk about fluid transfer within the servo which gives the problem you have.
That’s a first try and I got useful topics to look at. Then look at any associated topics listed below each of those topics (as you can see below this one) to see if there’s anything in them to help.
#5 Re: Brake Fluid
Post by mgcjag » Sat Aug 19, 2023 4:13 pm
