What type and size fuel line is used on early cars. I understand its while nylon but is it PA10 PA6 or PA12?
Fuel line material
#2 Re: Fuel line material
SNG BARRATT:
FS1001 ..... Fuel Line/metre
Michel
#3 Re: Fuel line material
And when you come to fit it to the banjo's be prepared for a fight. Tip: heat up the fitting, not the pipe, hold it in a vice and push the pipe on.
#4 Re: Fuel line material
To echo David, immersing the nylon pipe end in a mug filled with hot water from a boiled kettle worked well for me….its not easy….but it will work
#5 Re: Fuel line material
Thanks for your help. Will purchase from sng
