Headlamp flash
AshM
#1 Headlamp flash
Post by AshM » Wed May 01, 2024 4:05 pm
Just a quick confirmation please.
My headlamp main beam switch, to the right of the steering wheel, is also a headlamp ‘flash’ when the lights are off?
Mine only works when lights are turned on.
Just thought I would double-check before starting to seek the fault.
Ash
Series 2 FHC 1970
1R 20607
#2 Re: Headlamp flash
Post by mgcjag » Wed May 01, 2024 4:21 pm
Hi Ash...instructions are in the small buff Operating, Maintenance & Service Handbook....the headlamps can be flashed when the lights are off or when in the dipped beam position...but will not flash in the main beam position....Steve https://www.brooklandsbooks.co.uk/produ ... -handbook/
#3 Re: Headlamp flash
Post by Gfhug » Wed May 01, 2024 5:00 pm
Ash, don’t you get headlight flash by pulling the indicator switch towards you? I’ve never regarded the main/dip switch as a way to flash the headlights, except by flicking it up/down when the headlamps are on. Which is clumsy, at least imho, but everyone to their own.
AshM
#4 Re: Headlamp flash
Post by AshM » Wed May 01, 2024 7:18 pm
Goodness, I never knew that Geoff.
I shall try when next at the workshop.
After all, the car has only been in the family 51 years and 34 with me. Clearly still lots to learn!!! 😂😂
Ash
Series 2 FHC 1970
1R 20607
AshM
#5 Re: Headlamp flash
Post by AshM » Sun May 12, 2024 5:51 pm
Thank you Geoff.
My headlamps flash is, as you state, on my indicator stalk.
Every day is a school day! :thankyouyellow: :thankyouyellow:
Ash
Series 2 FHC 1970
1R 20607
#6 Re: Headlamp flash
Post by Gfhug » Mon May 13, 2024 9:40 am
:bigrin:
