Tacho generator
WEBSTER1357
#1 Tacho generator
Post by WEBSTER1357 » Sun Jun 02, 2024 7:35 am
The tacho has stopped working on my Series 1. I removed the tacho generator at the rear of the rocker cover and spun it up with a drill and the tacho in the car works. Any ideas whats going on here? Any thoughts or suggestions much appreciated.
#2 Re: Tacho generator
Post by mgcjag » Sun Jun 02, 2024 7:47 am
WEBSTER1357
#3 Re: Tacho generator
Post by WEBSTER1357 » Mon Jun 03, 2024 4:23 pm
Thank you that's a very informative article and tapping out the armature has fixed it. Tacho now working great advice many thanks.
#4 Re: Tacho generator
Post by abowie » Mon Jun 03, 2024 11:37 pm
The movement of the armature may be because the bush is loose.
If it happens again that probably needs addressing.
