e type oil filler cap rubber seal 3.8 series 1 1963
chrislaffey
#1 e type oil filler cap rubber seal 3.8 series 1 1963
Post by chrislaffey » Sat Jul 27, 2024 11:21 am
Hi can someone help me please. I need an oil seal for the filler cap where you put the oil in the engine, for the car. I am struggling to find the part number and where to get one from. Please if someone can let me know the quickest and best place I would be so grateful
thank you Chris
#2 Re: e type oil filler cap rubber seal 3.8 series 1 1963
Post by Heuer » Sat Jul 27, 2024 11:48 am
#3 Re: e type oil filler cap rubber seal 3.8 series 1 1963
Post by mgcjag » Sat Jul 27, 2024 12:04 pm
Oil filler cap seal 3.8...C419 in Jag parts catalogue and shown on sng as a fibre seal
https://www.sngbarratt.com/English/#/UK ... 202442559)
#4 Re: e type oil filler cap rubber seal 3.8 series 1 1963
Post by DWW » Sat Jul 27, 2024 4:53 pm
:yeahthat: where I bought mine….
#5 Re: e type oil filler cap rubber seal 3.8 series 1 1963
Post by bitsobrits » Sat Jul 27, 2024 5:43 pm
I run an O ring on mine. Seals without fail and doesn’t require high torque to do so. Size is not critical, just needs to be thicker, on the order of 1/8”, and slightly smaller than the OD of the cap just another threads.
And if you are really fastidious, you can find a size which will allow for precise ‘clocking’ of the filler cap with the Jaguar name dead in line with the cam cover. :)
JerryL770
#6 Re: e type oil filler cap rubber seal 3.8 series 1 1963
Post by JerryL770 » Sun Jul 28, 2024 10:26 am
I fitted a Monza type cap on mine, precisely because of the torque needed to remove the screw cap, which my old hands could not achieve.
Jerome Lunt
