Turn Signal Repeaters
nzmike
New Zealand
#1 Turn Signal Repeaters
Post by nzmike » Sun Sep 01, 2024 4:53 am
Hi all, the turn signal repeaters on the dash of my E Type have stopped working. I have used a test lamp and they are getting power, but it looks like they are not earthing properly. Is anyone aware of where the earth is for these? I cannot track it via the wiring diagram.
Michael Wood
S1 4.2 FHC
Iansparky
#2 Re: Turn Signal Repeaters
Post by Iansparky » Sun Sep 01, 2024 6:01 am
Try searching on Google for "servicing the jaguar e type series 1 turn signal switch"
There is a great article on yumpu that explains how to strip, clean and repair the switch
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
Iansparky
#3 Re: Turn Signal Repeaters
Post by Iansparky » Sun Sep 01, 2024 6:17 am
It is an annoying site with loads of pop up adverts although it is still possible to navigate around them to see the excellent article
1965 series 1 ots
2016 Caddy van
caveman
#4 Re: Turn Signal Repeaters
Post by caveman » Sun Sep 01, 2024 8:09 am
Theres an under dash earth point, near turn signal relay, far RH side & behind dash. If I remember rightly, it's a bolt on mine with a number of ring connectors.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
mtnjag
#5 Re: Turn Signal Repeaters
Post by mtnjag » Wed Sep 04, 2024 10:57 pm
Have you checked the flasher relay?
Layne
Car #876005, 62 OTS
