Courtesy light switch fittig
phoenix
#1 Courtesy light switch fittig
Post by phoenix » Mon Sep 02, 2024 2:16 pm
S1 FHC.
I am trying to fit the switches I purchased from well known supplier and they do not seem to be able to grip the tube where they fit. Also they don't seem long enough and do not operate. I.e.
Light stays on when doors closed.
,(I have fitted the small striker plate).
S1 4.2 RHD Bryan
#2 Re: Courtesy light switch fittig
Post by DWW » Mon Sep 02, 2024 5:15 pm
#3 Re: Courtesy light switch fittig
Post by Series1 Stu » Mon Sep 02, 2024 9:08 pm
Bryan,
I think there should be 2 of the small striker plates on each side (4 in total).
Allrand
#4 Re: Courtesy light switch fittig
Post by Allrand » Tue Sep 03, 2024 7:28 am
Had the same problem, typical repro parts from the usual suspects.
Randall Botha
#5 Re: Courtesy light switch fittig
Post by Series1 Stu » Tue Sep 03, 2024 10:23 am
Agreed, I have a pair of new reproduction switches in my surplus parts box because I accidentally found the original switches and they were so much better in every sense.
andrewh
#6 Re: Courtesy light switch fittig
Post by andrewh » Tue Sep 03, 2024 5:48 pm
Very often 2 chrome plates are fitted to make the distance correct. The reproduction switches need the spring retainer squashing with pliers to make them fit. However, I also found my originals and went with those.
1962 3.8 Series One FHC
phoenix
#7 Re: Courtesy light switch fittig
Post by phoenix » Fri Sep 06, 2024 3:27 pm
S1 4.2 RHD Bryan
Allrand
#8 Re: Courtesy light switch fittig
Post by Allrand » Sat Sep 07, 2024 8:20 am
How are those fitted, there's no access from inside the A post?
Randall Botha
#9 Re: Courtesy light switch fittig
Post by Series1 Stu » Sun Sep 15, 2024 4:37 pm
This is what they should look like.
These ones came from Martin Robey.
