Underbody protection
baganz.sven@web.de
#1 Underbody protection
Post by baganz.sven@web.de » Mon Nov 11, 2024 2:11 pm
Dear forum colleagues,
soon the shell of my S3 will be ready for the paintshop.
Now I'm thinking about underbody protection.
Do you use clean wax or how do you protect your car?
Or should I leave it just painted?
Best regards Sven
Sven
'71 S3 coupe LHD manual
71 V12
#2 Re: Underbody protection
Post by 71 V12 » Wed Nov 13, 2024 4:50 pm
Hello Sven,
Personally I would apply protection, it’s easier to clean off the protection than repair rust!
I have found Dinatrol clear to provide lasting protection. It needs to be applied with compressed air but can be used in sills with suitable applicator. I am sure your paint shop will have no problem.
Regards Kevin
#3 Re: Underbody protection
Post by MarekH » Wed Nov 13, 2024 7:56 pm
The bottom of the car will originally have had a coating of black underseal over the paint. If you are thinking of injecting anything prior to painting, remember that 2pack paint is oven cured at ~40'c.
#4 Re: Underbody protection
Post by chrisfell » Thu Nov 14, 2024 8:58 am
Dinitrol produced a chart showing where to apply rust proofing to an E-Type shell. It guided me to the various closed and semi closed box sections where, if unchecked, rust can start and eventually burst out. I think there is a copy in the knowledge base.
These preparations (Dinitrol, Waxoyl, Lanoguard, etc) are not fit and forget. They work best when just applied, 'wicking' into cracks and joints, but need regular maintenance sprays to keep them active and to recover areas of wear. I apply a thinned respray of Waxoyl every winter, inner and outer panels and box sections. This is on a car which has never had a full restoration, just a couple of minor tart-ups and resprays.
Craig Balzer
#5 Re: Underbody protection
Post by Craig Balzer » Thu Nov 14, 2024 5:05 pm
You said: "Dinitrol produced a chart showing where to apply rust proofing to an E-Type shell."
I did a cursory check of their website but couldn't find the chart.
Do you have a link?
Craig Balzer
Colorado Springs, CO, USA
paydase
#6 Re: Underbody protection
Post by paydase » Thu Nov 14, 2024 5:12 pm
Serge
1964 (3.8) FHC
1961 OTS
Craig Balzer
#7 Re: Underbody protection
Post by Craig Balzer » Sat Nov 16, 2024 8:34 pm
Getting back to the original question, it took me a while to find my notes but this is what my body/paint guy used on the under carriage of my Series III OTS. Sorry for the delay . . .
He uses TCP Global (online) Custom Shop Tintable Bed Liner. You need to have the color code for your paint and have your paint distributor mix up some. No binder like in the base coat; just tint. Three oz per quart of bed liner.
https://tcpglobal.com/pages/custom-coat-bed-liner
Here are a few happy snaps of the finished results:
I masked off the areas that would take the torsion bar reaction brackets and the mounting brackets for the IRS. I wanted a clean smooth surface form those contact points/areas.
Craig Balzer
