Need help with radiator header tank bracket part number
18000rpm
Singapore
#1 Need help with radiator header tank bracket part number
Post by 18000rpm » Thu Jan 30, 2025 8:01 am
Anyone know what's the part number for the bracket circled in red? I can't find it in the parts diagram.
Bryan
72 Series 3 2+2 Auto
Bob.
#2 Re: Need help with radiator header tank bracket part number
Post by Bob. » Thu Jan 30, 2025 8:53 am
Do you mean this bracket whch is part of the coolant pipe assembly?
Bob
'71 S3
18000rpm
Singapore
#3 Re: Need help with radiator header tank bracket part number
Post by 18000rpm » Thu Jan 30, 2025 9:54 am
You are absolutely right Bob! Didn't realize it is part of the pipe.
Great thank you! This should be the part:
https://www.sngbarratt.com/English/#/UK ... 6119f49a30
Bryan
baganz.sven@web.de
#4 Re: Need help with radiator header tank bracket part number
Post by baganz.sven@web.de » Wed Feb 19, 2025 10:36 am
you won't find the bracket alone at the known dealers.
Today only spare parts with attached (welded) brackets are available.
The early V12 have a seperate, screwed bracket (like mine)
So you either find a used part or replace the complete pipes.
Best regards
Sven
Sven
'71 S3 coupe LHD manual
