3.07 ratio diff. crown wheel+pinion in 2025
Philippe-J.
#1 3.07 ratio diff. crown wheel+pinion in 2025
Post by Philippe-J. » Wed Mar 05, 2025 9:28 am
Having a 67 E from the US, my rear axle ratio is 3.54. According to past threads dealing with ratio change, I thought it would be a simple matter to change it to the more desirable 3.07 (assuming I know a skilled mechanics to do the job)
Alas crown+pinion with the right ratio are no more easy to find. Or they might be of poor quality (and you know it only after few thousands of miles :mad: ).
Is there anyone who can 1/ convince me to keep the 3.54 ratio :wink: , or 2/ indicate a provider with stocks or good quality repros (UK or overseas) :fingerscrossed: ?
Thank you for your help.
Philippe-J
Sander
Denmark
#2 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by Sander » Wed Mar 05, 2025 11:10 am
A few years ago I did the change from 3.54 to 3.07 on my 1966 FHC. It is the best upgrade to my E-type ever! I bought the pin+crown from SNG Barret and have been very happy with the quality. It is manufactured in the UK by Tran-X who are part of the Quaife group. If they still supply SNG I can recommend you buy it.
Having said that, be aware that it is a very complicated operation which definitely requires that the person doing it knows the skill. It requires a lot of experience and patience to adjust so that you don't end up with a rear end that howls or otherwise has noises. I did the job my self but it was no easy task. You should expect that all bearings, oil seals, limited slip plates etc. also have to be changed. I ended up spending around €3500 just on spare parts. But it has been worth all the money. I have absolutely no noises from the rear end. I have driven about 10,000 km with it and have, among other things, been on a trip from Copenhagen to Florence, Italy.
Jesper
E-Type FHC, 1965 * XK120 OTS, 1950 * Volvo P1800S, 1964 * Volvo 145, 1972 * MGB, 1967 * Land Rover S3, 1972
#3 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by Gfhug » Wed Mar 05, 2025 1:20 pm
Speak to Alan Slawson http://www.ajsengineering.com/ he’s the best man to talk to.
Philippe-J.
#4 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by Philippe-J. » Wed Mar 05, 2025 3:19 pm
I noticed that from my previous readings, but his answer is he does no more trade outside UK since brexit :thumbdown: .
That's the reason for this thread: is there any alternative today, such as buying a Dana ring+pinion + other adaptation stuff? Again assuming I can find a skilled mechanics that can deal with all these spares.
Philippe-J
#5 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by Gfhug » Wed Mar 05, 2025 4:46 pm
It’s a bit late for the retro-classics show (last weekend) but could it be worth looking at the list of exhibitors to find someone on there who could supply parts or rebuild for you?
#6 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by mgcjag » Wed Mar 05, 2025 5:19 pm
Phillipe....do you get over to the UK....Jag Spares day is on soon...I could possibly have a 3.07 there....Steve
#7 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by Gfhug » Wed Mar 05, 2025 6:16 pm
Philippe, that is a very good option for you. Even if you can’t get to Spares Day there are others from France who get over, maybe they could collect for you?
ralphr1780
#8 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by ralphr1780 » Wed Mar 05, 2025 8:29 pm
Philippe, you cannot simply fit a crown and pinion from a 3.07 into a 3.54 casing.
You do need a 3.07 casing which could be coming from a saloon hence without LSD, into which you will fit the LSD out from your 3.54 with the crown and pinion of the 3.07.
Hope this is illustrative and I am sure others will confirm.
Ralph
'69 OTS + '62 OTS - Belgium
Doug Buchan
#9 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by Doug Buchan » Wed Mar 05, 2025 10:07 pm
You shouldn't have to change the diff casing... never heard of this. Swapping a 3.54 for a 3.07 is done all the time. If you go down to a 2.88 it may require a spacer on the ring gear.
Doug
'67 ots
angelw
#10 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by angelw » Thu Mar 06, 2025 3:17 am
Doug is correct, there is only an issue when trying to fit a 2.88 gear set into a housing than contained lower ratio gear sets.
#11 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by abowie » Thu Mar 06, 2025 3:30 am
angelw
#12 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by angelw » Thu Mar 06, 2025 4:38 am
Hello Andrew,
I've not had a gear set from SNGB in my hands, but I believe there is no Back Lash detail marked on the Crown Wheel.
Philippe-J.
#13 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by Philippe-J. » Thu Mar 06, 2025 8:44 am
Thank you all for your posts.
Who knows about IWE? They have a classified on eBay for a Dana 44 crown+pinion 3.07 for a reasonable price.
Edit: link here: https://www.ebay.fr/itm/155274458768?mk ... name=11051
They are some posts about fitting such a stuff (e.g. viewtopic.php?f=3&t=13728&hilit=dana). Is there any prohibitive drawbacks?
Philippe-J
#14 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by mgcjag » Thu Mar 06, 2025 8:50 am
Hi Phillipe put a post in the wanted section....you may get lucky and someone in france has one...Steve.
Ps IWE seller ebay....you need to give us a link
#15 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by mgcjag » Thu Mar 06, 2025 10:42 am
There is a 3.07 ready to fit here...they may ship to France? https://www.ebay.co.uk/itm/224846622699 ... media=COPY
ralphr1780
#16 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by ralphr1780 » Thu Mar 06, 2025 12:20 pm
I had a different experience : the pinion of the 3.07 had a smaller OD, coming from a saloon without LSD, so I had to swap internals. :shrug:
Ralph
angelw
#17 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by angelw » Thu Mar 06, 2025 11:43 pm
Hello Ralf,
Well, of course the Pinion Gear itself will be a different diameter, and it would be a larger diameter for the higher geared 3.07 gear set; therefore, I assume you're referring to the bearing journal diameters of the Pinion Shaft being a smaller diameter. If so, I've never seen that in any of the various gear sets for Salisbury Differentials.
I have Pinion Shafts from 3.07 and 3.54 gear sets to hand and measuring them as I write this. The front and rear bearing journals of each shaft measures 30.42 and 34.95 respectively within a very small tolerance, the same as all other Pinion Shafts for Salisbury differentials.
ralphr1780
#18 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by ralphr1780 » Fri Mar 07, 2025 12:58 pm
Hi Bill, you must be right, frankly I don't recall full details, but what I now remember is that I had 3 diff simultaneously opened on the bench: the original 3.54 from my car, a 2.88 and a 3.07 from MK2.
The 3.07 pinion and crown had been a straight swap into the 3.54 casing, but not the 2.88 I had initially opted for. That was 25y back...apologies to all for the confusion :banghead:
Ralph
Philippe-J.
#19 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by Philippe-J. » Thu Mar 13, 2025 4:27 pm
Another valuable track for crown wheel and pinion?
I found it in viewtopic.php?f=7&t=13710&p=111696&hili ... ar#p111696. Northern Tool & Gear sell CW&P made for E Types
https://www.ntgear.co.uk/product/e-type-jaguar/,
and prove to be of good will when asked information about their product. On top of this their price is appealing.
Isn't it too much to hope for? First the number of teeth is not the usual one (16/49 vs 14/43). Second I can't find much feedback about them on E Type sites :scratchheadyellow:
Anyone has experienced them? Should I go with it for my ratio swap?
Philippe-J
lowact
#20 Re: 3.07 ratio diff. crown wheel+pinion in 2025
Post by lowact » Thu Mar 13, 2025 10:49 pm
Wish I'd known about this. Before I replaced the 3.54 in my S3 with an S1 3.07 from SNGB. Had to use one different bearing because the SI pinion shaft is smaller diameter. And use shims instead of the crush sleeve.
