Series 3 automatic transmission slipping
Jeremy1954
#1 Series 3 automatic transmission slipping
Post by Jeremy1954 » Thu Apr 24, 2025 9:43 pm
Hi, my Series 3 BW 12 is slipping in reverse gear. It’s also slow to shift into third gear. Can this be adjusted ‘in situ’ with the oil pan removed? The oil doesn’t appear to be contaminated.
#2 Re: Series 3 automatic transmission slipping
Post by Gfhug » Sun Apr 27, 2025 7:32 pm
Jeremy, just to help others, have you read and carried out all checks and adjustments shown in the owner’s workshop manual? viewtopic.php?f=16&t=700
There seems to be a lot of information in the manual to sort out problems with all parts of an E Type, including auto boxes. If you can show what you’ve done then it will help the wise ones to guide you.
